Trident-Exhausts.comAdvanstarMotorcycleShowsBikeBandit
Old 04-17-2008   #1 (permalink)
Favorite Bike: Sprint 1050
karl6262's Avatar
Knocking Noise When Pulling Off
I have a 05 1050 Sprint with 10500 miles on the clock. When pulling off from a standing start, I am getting what I can only describe as a clonk from what seems like the chain. I have had a look at the sprockets, and there appears to be a little wear on the rear one, the front looks fine, and the chain seems to be within the specs. Seems a little early to me for these items to be reaching there limits. Has anyone had the same problem? Gonna try and get it to the local dealer and see what they think.
karl6262 is offline   Reply With Quote
Old 04-17-2008   #2 (permalink)
Favorite Bike: 07 speedmaster
wildchild's Avatar
Other Motorcycle: 07 675 Daytona
Your chain isn't to tight and binding is it
toys for big boys
wildchild is offline   Reply With Quote
Old 04-17-2008   #3 (permalink)
Favorite Bike: 06 Sprint-Argentum Celer
oldndumb's Avatar
Are you asking if anyone else has had this problem, or are you maybe asking for possible causes?
Oldndumb
Caveat lector
oldndumb is online now   Reply With Quote
Old 04-17-2008   #4 (permalink)
Favorite Bike: 2005 sprint
rodsprint's Avatar
Other Motorcycle: gs 550
Extra Motorcycle: cz 250 1932
Last time i heard a knocking noise when pulling off, i just put it away and pretended to adjust my pants
On the road to anywhere
rodsprint is offline   Reply With Quote
Old 04-17-2008   #5 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
Safe
Probably the safest course of action Rod
DaveM
DaveM is online now   Reply With Quote
Old 04-17-2008   #6 (permalink)
Favorite Bike: 2006 Sprint st
theBarzeen's Avatar
noise???
I finally got my new ( to me) '06 out for a ride a little bit ago and I heard something similar.... I was hearing it from a stop a little, and both hearing and feeling it through the pegs whenever the pavement got a little bit scrubby ... I figured it was probably just the centerstand banging around... but now you have me worried too
theBarzeen is offline   Reply With Quote
Old 04-17-2008   #7 (permalink)
Favorite Bike: 2006 Sprint ST
thinkjerm's Avatar
Did you adjust the chain recently? If you spin the eccentric you will get the same problem.
thinkjerm is offline   Reply With Quote
Old 04-17-2008   #8 (permalink)
Favorite Bike: 2007 Bonne Black
Calliway's Avatar
Other Motorcycle: 2005 Sprint ST 1050
Chain or valvetrain. Your valves will clatter if you have low octane fuel, they need adjustment or if you are running in the wrong gear with to low or rpms for it.
Chain adjustment as others have noted.
Calliway is offline   Reply With Quote
Old 04-18-2008   #9 (permalink)
Favorite Bike: My '06 Sprint ST - C/Blue
BallaRAT_ST1050's Avatar
Well done Rod
4th post in - I knew it was coming
but I still pi$$ed my self laughing
Followed up by DaveM - always better to be safe than SPRUNG
Work to Live : Live To Ride
BallaRAT_ST1050 is offline   Reply With Quote
Old 04-18-2008   #10 (permalink)
karl6262's Avatar
Love the sense of humour. Left myself wide open for that one. OnD asking both really. Had a closer look at the sprockets and if there is wear it is very minimal.
I have not adjusted the chain for a while as it did not seem to be out of spec. I always have it on the loose side. Gonna tighten it up a little and see if that will eliminate the problem. I was concerned that it might be something more sinister. Ever the optamist!!
The noise is coming from the chain area, I am sure it is not coming from the valve train.
Engine Noise (sounds like lifter knocking) Dive2277 Sprint Forum 13 03-12-2007 10:53 AM
clonking noise pulling away davsato Sprint Forum 16 12-23-2006 04:57 AM
TBA pulling to the right? HELP!!! dseely Twins Technical Talk 6 11-17-2006 03:28 PM
Am I pulling to many RPMs medicinthewind Trophy 8 07-24-2006 07:23 PM
HELP! Knocking noise. fonebone Speed Triple Forum 8 08-01-2005 11:55 PM
