» Links |
| Sprint Forum Sprint ST and Sprint RS - Join in on one of the world's most active Triumph Sport-Touring Forums. |
04-15-2008
SuperSport Favorite Bike: 2006 Triumph Sprint ST
Bad Coil...
I just got an email from RICKYT and he says that they found a bad coil as the culprit...the tech states that the coils on triumph and kawasaki products are notrious for going bad if stored for long periods. Anyway hear of this issue?
Ricster
Save an animal....adopt and give someone less fortunate a home
Supersport 600 Favorite Bike: Anything Triumph
Thats what the Tech believes. Bike ran good a certain RPMs but not at low. Apparently its going bad and while they rode my bike, the coil worked fine for a minute and the bike ran great but then it went on the fritz and the bike ran like crap. It seemed to run better at higher rpms and if he really redlined it, the problem would go away for a few minutes thn reocur
One weird side note. He originally though I had one cylinder not firing because the middle pipe on the exhaust (Tridents) was soot free and cold while the other two had plenty of heat and a bit of a build up. Only catch was there is only one pipe feeding into three exhaust pipes. The air could possibly sort itself like that. Anyone else have seen this?
As a child I would never look before I would leap. Things are different now, but I still leap.
04-15-2008
SOTP Vintage Series Favorite Bike: 06 Sprint-Argentum Celer
Ricster
I've heard that the twins are hard on coils, but I have not heard that said about the triples.
Oldndumb
Caveat lector
04-15-2008
LOL....you have three header pipes feeding into one, and then feeding into a mid-pipe with three outlets. You do not have three exhaust pipes hanging on the rear of the bike. They are cans/mufflers/silencers.
Oldndumb
Caveat lector
04-15-2008
Immoderate Moderator
Site Supporter SuperSport Favorite Bike: '04 Sprint RS
Posts: 1,109 Other Motorcycle: Dead '96 Trident Extra Motorcycle: Dead '76 KZ400
The coils for the 885 triples are notorious for going bad, but that's not something I've ever heard about the 955/1050 stick coils. My experience with Kawasakis ends with the 1980 model year, so I won't comment on those.
Cheers,
-Kit
04-17-2008
Grand Prix 125 Favorite Bike: 07 Sprint (ABS)
I had a long and expensive run in with coils on a 2000 Trophy.
Short answer... The plug lead to spark plug connection was iffy. Unfortunatly they sent me a three lead set, and it was number 4 that was the problem. Tested OK but did in 6 coils over ten months.
Check the spark plug connection...be fussy.
Good luck
04-17-2008
SuperSport Favorite Bike: 07 Triumph Sprint ST ABS
Posts: 1,019 Other Motorcycle: 06 Suzuki 650 DR
I fail to see how not using a coil could damage it.......
Got 6 Pots?
- Tokico 6 pot calipers & Gafler HH pads
- PowerBronze Shield & Pazzo levers
- Trident Exhaust, TOR & 18T front sprocket, speedo healer, 2k bars
- Skyking Frame & MV rear axle sliders, Clear Alternatives smoke tailight, 6k HIDS
04-17-2008
World SuperBike Favorite Bike: 2007 Bonne Black
Posts: 2,335 Other Motorcycle: 2005 Sprint ST 1050
Corrosion. I am not sure if these coils are oil filled but I doubt that they are. The weather gets cold outside and things frost. Frost is condensation. THe weather warms up, the frost melts and now you have water in the coil which corrodes.
04-17-2008
Thanks. Makes sense.
Got 6 Pots?
04-18-2008
Mine is the same It's the new pipe configuration I suspect. minimal flow to the center can.
Piles of Miles with Smiles
