No Dyno with Carbon/Titanium mufflers? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 04-15-2008, 12:41 PM   #1 (permalink)
Favourite Bike: '06 Sprint St
GixxerMeThis's Avatar
I just received my Carbon Fiber Two Bros. slip-on for the 06 ST. At the bottom of the instructions is a note that reads
"Never dyno test your bike with carbon fiber or titanium canisters installed - the intense heat and lack of cooling air can quickly burn through the canister material. Two Brothers Racing does not provide a warranty for burned canisters."
Is there truth to this, or is it just their legal department covering their bases?
GixxerMeThis is offline   Reply With Quote
Old 04-15-2008, 12:55 PM   #2 (permalink)
Favourite Bike: 2006 Triumph Sprint ST
ricster's Avatar
Maybe (wolf) Peter Sorell can chime in about the tridents with carbon fiber...I bet his can take the dyno runs no problem....PETER??
Save an animal....adopt and give someone less fortunate a home
ricster is offline   Reply With Quote
Old 04-15-2008, 01:10 PM   #3 (permalink)
Favourite Bike: Velocette Clubman
Calliway's Avatar
Other Motorcycle: 2007 Bonnie Black Cafe
Extra Motorcycle: 77 GS400
Yeha Peter uses that fancy carbon so maybe that is why he can dyno his cans.
The other thing is that is an easy way for them to seperate themselves from any dyno guys who may not know what they are doing.
Calliway is online now   Reply With Quote
Old 04-15-2008, 02:01 PM   #4 (permalink)
oldndumb's Avatar
That is a fairly common disclaimer. A competent motorcycle dyno tuner will have sufficient fans in the cell to compensate for the lack of ram air. If they don't, ride away.
I think that Peter has said that his carbon fiber has a higher heat rating. There must be some differences between the brands because I have noticed some CF cans with brown discoloration.
Oldndumb
Caveat lector
Old 04-15-2008, 02:10 PM   #5 (permalink)
Favourite Bike: 06 Sprint ST 1050 ABS
KevyKev's Avatar
Other Motorcycle: 91 Suzuki Katana 600
+1 OND. I think that Peter's website also addresses the issue----something about his carbon fiber is rated much higher than run of the mill stuff. Either way, I think/agree that a good dyno shop would have the proper fans to take care of this..........but I haven't dynoed anything!
KevyKev is offline   Reply With Quote
Old 04-16-2008, 05:14 AM   #6 (permalink)
Senior Member - Site Sponsor
Favourite Bike: 1968 Bonneville T120
Wolf's Avatar
Most carbon commercially available is only rated to around 180 degrees before the resin breaks down or discolours - easily acheived when you have 800 degree gases flowing 2" from the carbon with just a bit of insulation between. We buy expensive stuff from Holland (us and Akrapovic now) which is good to 450 degrees. But so far no one in the US uses this carbon because it costs over double what the standard stuff does and so may not stand up to the heat of dyno testing.
Regards
Peter Sorrell
Trident Exhausts
www.trident-exhausts.com
Triumph Only Exhaust Specialists
Wolf is offline   Reply With Quote
Scrambler TOR mufflers vs Thunderbile powersports mufflers Davorallyfan Twins Technical Talk 18 08-20-2009 01:18 AM
carbon fiber or titanium?? warped929RR Speed Triple Forum 14 05-21-2007 12:52 PM
FMF Titanium Pipe Catenaccio Triumph SuperSports 5 11-19-2006 09:35 PM
Full Titanium exhaust for S3? carbster09 Speed Triple Forum 0 01-04-2005 10:34 AM
MHP TITANIUM EUROTWINS Daytona Deliberations 2 06-25-2004 02:40 PM
