04-13-2008, 09:35 PM
Grand Prix 500 Favourite Bike: '08 Red Sprint ABS
Posts: 102 Other Motorcycle: '04 suzuki SV650 (rebuild Extra Motorcycle: '01 Sprint ST
Installing TBR Slip On
This installation seems simple enough, but before I got too far down the line, I thought I'd ask you guys...just got a TBR Slip On exhaust for my '01...I am doing the standard mount...I thought I had it down...but they include some fittings called their V.A.L.E system...but no real instructions for the Sprint...I am assuming that I can use this rather than the supplied hi-heat silicone to connect the slip on to the s-pipe. Instructions are install the slip on directly to the s-pipe.
Have any of you installed the VALE?
Thanks as always
04-14-2008, 03:52 AM
Super Daffy Moderator
Site Supporter Nova Favourite Bike: 2011 Sprint GT 1050
Posts: 17,626 Other Motorcycle: 2004 Daytona 955
try Pm'ing this guy
Smegin,
has installed a Two Bros onto his 955 Sprint.
Why not send him a PM?
DaveM
04-14-2008, 04:05 AM
SuperBike Favourite Bike: 2002 RS
Posts: 1,533 Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
The Vale system is a tuneable pipe. it installs in the end cap to quiet down the pipe if you wish. 3 db I believe. You will still be mounting the main pipe assembly as any other TBR pipe, with the silicone sealant as well.
04-27-2008, 09:00 PM
Thanks for the advice...I've PM'd him...but I thinkI know what the issue is...I don't think it is meant to be mounted to a ST with panniers...looks like it would slide into place perfectly if I took the brackets off...really not an option for me since I commute a lot on it and take a few long weekenders...
If anyone out there has any thoughts I'd appreciate it...hate to have blown $330...
04-27-2008, 09:13 PM
Site Supporter SOTP Vintage Series Favourite Bike: Velocette Clubman
Posts: 7,015 Other Motorcycle: 2007 Bonnie Black Cafe Extra Motorcycle: 77 GS400
Isnt there a high mount and a low mount with the STs? The low mount is for a bike with panniers is it not?
04-27-2008, 09:19 PM
That was certainly my thought process...the clamp seems to be about an inch too short...I could probably have one of the guys at work weld up a bracket for me, but I'd rather not.
04-27-2008, 11:30 PM
Formula Extreme Favourite Bike: '08 Neon Blue Daytona 675
Posts: 891 Other Motorcycle: '02 Sprint ST (RIP)
Are you talking about the bracket that comes with the panniers to lower the stock muffler? Is that bracket not positioned properly to drop the tbr exhaust enough to fit the panniers?
04-27-2008, 11:37 PM
Sigh, thank God for underseat exhaust.
04-28-2008, 12:03 AM
Hey Panther...I knew you bought the high pipe...the pipe I'm replacing is a D&D that was getting pretty trashed...it was mounted to the rear peg bracket...maybe I'm missing a piece that was at the pannier bracket?
04-28-2008, 12:18 AM
You must be missing something because the earlier sprints had a high mount and a low mount to accomadate the panniers so there must be a bracket that is missing. Look on bike bandit and see.
