Rod,
If you try the fix (differential) and still have noise, add a short wire between the negative cap terminal and chassis (common mode) leaving all other wiring as is.
You are likely to get a small spark when you first charge the cap. Don't worry about it unless you want to. If you must worry, get a 1 Ohm 5 watt resistor to precharge the cap before connection. Use it before you connect battery terminals in the future as well. Again, it shouldn't be required.
Originally Posted by rodsprint
clb. Unswitched so i will try your fix.
Thanks guys. Rod
