Need assessment of these sprockets - Triumph Forum: Triumph Rat Motorcycle Forums
 3Likes
post #1 of 12 (permalink) Old 04-19-2017, 05:06 PM Thread Starter
Main Motorcycle: Sprint GT
I've been considering dropping the front sprocket of my GT down to 18 teeth. I bought the bike with 18k miles and it now has 24k miles so I figured it was time. The wear on the sprockets is not what I expected and I have no frame of reference. Attachments are a little blurry, I'm wondering if the previous owner has already done a chain/sprocket replacement. Chain is about 1mm shy of its max recommended spec of 321mm for 20 links. I'm wondering if I can get away with a front sprocket change, or should I just be safe and swap out everything.
ID:	464394   Click image for larger version
pdxmatt is offline
post #2 of 12 (permalink) Old 04-19-2017, 05:47 PM
Main Motorcycle: 2006 Sprint ST
MileHighScottie's Avatar
Other Motorcycle: 2003 Sprint ST (her's)
Extra Motorcycle: 2014 Thruxton (gone)
My thought? Sprockets are cheap. Buy new ones.
cafecruzin and lennart0r like this.
-- Scott
MileHighScottie is online now
post #3 of 12 (permalink) Old 04-19-2017, 06:17 PM
Main Motorcycle: '98 T595 Daytona
Other Motorcycle: 2014 Ninja 1000ABS
Those sprockets look barely worn. I doubt they are the original set. My new rear sprocket wasn't cheap, but since you want to change out the front, I would also do the rear. No need to look back or second guess your decision to go new.
Felony is online now
post #4 of 12 (permalink) Old 04-20-2017, 01:24 AM
Main Motorcycle: Black '04 Sprint RS
Immoderate Moderator
KitNYC's Avatar
Other Motorcycle: Blue '04 Sprint RS
For $20, I'd swap the front now and do the rest when the chain goes out of spec if that happens within, say, the next 10k miles. If the chain lasts longer than that, then I'd do everything next time around.
Cheers,
-Kit
'04 Sprint RS * Penske 8983 * Traxxion AK20s * Zero Gravity sport touring screen * Oxford heated grips * DGD keyless ignition * Relocated seat lock * Givi saddlebags with custom mounts * Fuzeblocks FZ-1 power block * Adaptiv TPX radar detector * Garmin GPS in RAM Aquabox * Garage door remote * Tokico six pots * Pazzo shorty levers * Voltmeter * Yoyodyne gas cap
KitNYC is offline
post #5 of 12 (permalink) Old 04-20-2017, 05:09 AM
Supernova
Main Motorcycle: 2011 Sprint GT 1050
DaveM's Avatar
Extra Motorcycle: Previously - Many
Be aware that by reducing the front sprocket to less teeth you will put more wear on the top rubber wear strip on the top of the swing arm.
If you want lower gearing on a Sprint RS, ST or GT or a Daytona 955i it is probably better to increase the number of teeth on the on the rear sprocket.
Cheers
DaveM
DaveM is offline
post #6 of 12 (permalink) Old 04-20-2017, 08:17 AM
Main Motorcycle: Tiger Sport
Paul49's Avatar
Other Motorcycle: Tiger 800 XRx
Extra Motorcycle: Ariel Huntmaster
That front sprocket won't be the original, It would be worse than that. I replace the fronts at 15k miles, then the full set when the chain is worn at 30k miles.
Your chain sounds like it's on its last legs though, so best to replace the full set shortly. Like DaveM says, best go up 2 or 3 teeth on the rear.
Use gearing commander to check the best combination of teeth & links to avoid excess wear, 19/45 looks good.
http://www.gearingcommander.com/
Paul49 is offline
post #7 of 12 (permalink) Old 04-20-2017, 08:57 AM
Main Motorcycle: 1977 Triumph Bonneville
Other Motorcycle: 1996 Ducati 900ss/cr
Extra Motorcycle: 2007 Ducati S4RS
Would you even have enough adjustment left if you put on a smaller front sprocket ?
duc96cr is offline
post #8 of 12 (permalink) Old 04-20-2017, 09:53 AM
Main Motorcycle: '03 Sprint ST
pushr0d's Avatar
Other Motorcycle: 2000 Sprint ST (wrecked)
Extra Motorcycle: 1988 FXR Lowrider (sold)
I dunno. Those sprockets look 'wallered out' to me.
Like MHS said, sprockets are cheap. Buy a complete chain and sprocket set and get that warm fuzzy feeling.
There are several threads on sprocket setups in this forum, so you can (maybe) figure out which way you want to go with 'gearing'.
pushr0d is online now
post #9 of 12 (permalink) Old 04-20-2017, 10:30 AM Thread Starter
Thanks guys, the info really helps... except for that gearing commander website. That's the kind of place I'll get stuck playing with numbers for hours!
pdxmatt is offline
post #10 of 12 (permalink) Old 04-21-2017, 04:51 AM
KitNYC's Avatar
This is true as a general rule, but going from the stock 19 down to the originally stock for first year STs 18 is not a big deal and won't do much to increase rubbing strip wear.
I see a little bit of wear on that front sprocket, but the rear still looks practically new to me. 1mm of stretch is actually a fair bit of wear on a steel chain.
Cheers,
-Kit
KitNYC is offline
New chain and sprockets. KitNYC Sprint Forum 48 05-05-2017 10:05 AM
Replace chain only, or chain & sprockets, on T140V? Rod Rocket Classic, Vintage & Veteran 28 04-05-2017 01:35 PM
GT chain and sprockets change Jono 67 Sprint Forum 10 10-14-2016 08:58 AM
Recommend me sprockets and chain (Tiger 955i 2005) Please Rev-O Tiger Chat 1 07-30-2016 10:33 AM
