Originally Posted by phillipjg
Thanks. I forgot to mention, I've checked both(!) the fuses and lamps, but they all seem to be OK. Still no lights!
Philipjg
It's odd that both headlight relays are knackered but these things can happen. You don't mention whether you've checked the headlight cutout relay.
This relay cuts power to the headlights when the starter relay is activated. If this relay is stuck in the open circuit then you're light wont light because it removes power from the main and dip relays.
If the coloured tags are still on the harness, the yellow tag is the headlight cutout relay. If the tag is missing the wire colours are Blue, Black, Yellow/Blue & Red/White. That's from the Haynes manual. hope it helps.
