I hope you are not hoping for a hands off answer.
If it were me I would check and verify all battery connections, including the battery negative to engine case ground. Then I would do the following checks. They are what I have always done regardless of bike marque. I am not saying the dealer did anything wrong. I am suggesting that you can verify the conditions for your self. Start the tests with a battery charged to 12.7vdc minimum. Disapate any surface charge by turning the ignition on for about 6 or 7 minutes, then do the tests. Let us know what you come up with.
Do a charging voltage test.
Note: The battery must be fuly charged for this test to be valid.
1. Have bike at normal running temperature.
2. With ignition off, connect a VOM to the battery.
3. Start the bike.
4. Run the revs up to about 3K and check the voltage reading. It should be around 13.5 to 15vdc. It should not go below 13.5vdc. If it does, the alternator is suspect.
5. If the voltage is over 15vdc, the regulator/rectifier is probably bad.
Do a "Drop" test. (shadetree load test)
Note: The battery must be fully charged for this test to be valid
1. With ignition off, connect a VOM to the battery
2. Switch on ignition with lights on and operate the starter.
3. The battery vdc reading will typically drop but it should not go below 9.5vdc.
4. It it goes below 9.5vdc, the battery is probably bad.
PS.....your search button must be inop because you have been on the forum for a while now.
