Rear Brake Mounting Plate- Play? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-26-2008, 07:51 AM   #1 (permalink)
Favourite Bike: 2008 BMW R1200GSA
Groucho's Avatar
Did some work to my bike this weekend, cleaning the chain, etc. I had just had new tires mounted, so the rear wheel was recently off.
One think I noticed- there is a little bit of "play" in the plate that the rear brake calipers are attached to. Not much- just enough to make it "rattle" if you grab the caliper assy. The calipers themselves are bolted securely to the plate.
Is this normal?
"When in doubt, gas it. It'll either solve the problem, or remove the suspense."
Groucho is offline   Reply With Quote
Old 02-26-2008, 07:57 AM   #2 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Groucho
Please confirm what I say with those that know much more than me.
But my answer would be yes, it is supposed to be able to move.
I am not overly technical though so we will see what the clever ones say
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 02-26-2008, 08:06 AM   #3 (permalink)
Groucho's Avatar
DaveM
Thanks Dave. I suspect so as well, but the pilot in me likes to make double-****ed sure on items that are flight-critical.
Old 02-26-2008, 06:13 PM   #4 (permalink)
Groucho's Avatar
*bumpity*bump*
Old 02-26-2008, 06:26 PM   #5 (permalink)
oldndumb's Avatar
Originally Posted by Groucho View Post
*bumpity*bump*
I hope you didn't do the "bumpity bump" thing because you doubted Dave's answer, because he is correct.
Remember, always bet on three, and always bet on the Mods.
On a serious note, a lack of movement could indicate problems.......like galvanic corrosion and the attendant binding of parts.
Oldndumb
Caveat lector
Old 02-26-2008, 11:43 PM   #6 (permalink)
Favourite Bike: 2000 Sprint RS
Other Motorcycle: 82 BMW R65LS
perfect timing! I just noticed this myself. One less thing to worry about
JohnB is offline   Reply With Quote
Old 02-26-2008, 11:57 PM   #7 (permalink)
Groucho's Avatar
Gotcha. Thanks OMD.
And I would never deign to doubt The Dave... I was just looking for some triangulation.
Noisy rear brake caliper mounting bracket spm0912 Speed Triple Forum 0 07-17-2007 03:00 PM
That "clunk"..........rear caliper mounting plate questions dazco Twins Technical Talk 7 09-26-2006 02:23 AM
Bonneville brake pedal mounting plate Digby Twins Talk 1 06-21-2006 11:51 AM
Rear brake play. sailor Speed Triple Forum 0 05-17-2005 03:28 PM
play in front brake disks timmmy Triumph SuperSports 7 05-13-2005 02:58 PM
