Cam chain on 1050's - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-16-2008, 11:41 AM   #1 (permalink)
Favourite Bike: BMW R1200GS Adv.
Exclamation Cam chain on 1050's
At my 40kkm service my dealer noticed that he could not get the timing right, and took the engine apart and found that the cam. chain was worn and it was changed on warranty.
So today I was at the dealer to pick up some plastic stuff, and he mentioned that there seams to be a general issue with all 1050's, at least up to mid 2006, where the spanner of the cam chain is faulty (I'm not mechanical, and don't understand all of it).
As far as I know Triumph know about the issue, and owners will get this fixed under warranty. I had it done, but as they later found that it it have to do with the spanner they will have to take the engine apart again at 60kkm, which is a 6 hour job - they are looking to see if they somehow can get Triumph to swallow it as a warranty job even if the bike is 3 years old.
Casper
casperghst42 is offline   Reply With Quote
Old 02-16-2008, 02:10 PM   #2 (permalink)
Favourite Bike: 2006 Triumph Sprint ST
ricster's Avatar
I just gave this information to the triumph service manager here in CT. to see what Triumph has on this.
Save an animal....adopt and give someone less fortunate a home
ricster is offline   Reply With Quote
Old 02-17-2008, 06:28 AM   #3 (permalink)
Favourite Bike: I like all my Bikes
gsbeamer's Avatar
Other Motorcycle: Sprint 1050
Extra Motorcycle: BMW R1100GS
Ricster........PLEASE keep us posted on this one....
Here I am thinking I have an Engine that is " Bullet Proof " and
will do well over 100,000Ks......then you read something like this.
Life is never simple.
gsbeamer
You can have everything you want in life, if you are happy with simple things, and Motorcycles.
gsbeamer is offline   Reply With Quote
Old 02-17-2008, 01:13 PM   #4 (permalink)
Favourite Bike: '10 Tiger 1050
Other Motorcycle: 1996 Sprint885
This isn't anything new from Triumph my 96 Sprint had a horrible cam chain tensioner failure at 30k "the dealers response was the blades that hold the rub strip were made of low grade steel this isn't the first one he had seen". Now I own a nice boat anchor...all the valves smashed the pistons due to this little whoops.
Some people smoke, some people drink,
I ride Triumph motorcycles.
96sprintrydr is offline   Reply With Quote
Old 02-17-2008, 04:25 PM   #5 (permalink)
oldndumb's Avatar
How quick we panic.
Lets wait until some members have had a chance to get more info.
Casper, since you are the originator, any chance that you could get a little more specific info from your source?
96sprintrydr, are you certain about the metal blade? This design is not unique to Triumph and all that I have seen had blades made out of some sort of synthetic material, certainly not metal. But, then I've not been into a 96.
Oldndumb
Caveat lector
Old 02-17-2008, 06:08 PM   #6 (permalink)
Originally Posted by oldndumb View Post
How quick we panic.
I'm as sure as the parts of sharpnal I dug out of the housing. Piss poor material.
Old 02-17-2008, 06:13 PM   #7 (permalink)
The only thing I know is;
At my 40kkm service he was not able to get the timing right, and after taking the covers of the engine he found out that the cam chain was slack, and pulled roughly 10mm longer than it should be - as far as I remember, this happened in June last year.
This Saturday I was there and he told me that it comes down to the spanner (is that the right word/term) of the cam chain, which is not constructed correctly. In the last 2 months he have changed it on 3 ST 2005/2006 engines under warranty - 2 did not have the problem, but had the 'operation' done as he had them in anyway, and one showed the same signs as mine did (hear say information). I would say that if Triumph covers it under warranty on 3 bikes then it is something they know about.
I was told - my bike is now at 52kkm - that I should not be worried driving it until the 60kkm service.
I rode 40kkm with this issue without any problems, except that the last 5-10kkm the engine wasn't running smoothly, now (still) it sounds ok. There was absolutely no problems at the 20kkm....
Currently my problem is that it will cost me a fortune to have this fixed if Triumph does not cover it, as my bike was 2 years old in July last year.
Casper
How quick we panic.
Old 02-17-2008, 08:36 PM   #8 (permalink)
Rumours
The problem here is if you go to your dealer they will play dumb (eg "what cam chain problem is that?"). I had this response for months regarding the rear suspension linkage problem prior to Triumph making it official. The dealers use the same WEB access thing we do to see if a particular VIN has outstanding warranty work. Having a pro-active dealer who chases these things up is a very rare thing, you are lucky indeed.
MickSprint06 is offline   Reply With Quote
Old 02-18-2008, 05:12 AM   #9 (permalink)
Favourite Bike: Speed3 -09
Martin_R's Avatar
So are we talking faulty cam chain tensioners here or faulty tensioner blades?
Martin_R is online now   Reply With Quote
Old 02-18-2008, 07:51 AM   #10 (permalink)
Absolutely no clue, as I have no mechanical knowledge. But he told me that he needs to get the top of the engine to fix the issue.
The more I've been thinking about it, the more nervous I get - I'll see if I can find time to get around the dealer (120km away) this saturday to get more information about what exactly the problem is.
Casper
Cam Chain truckie Trophy 10 01-14-2008 04:41 PM
Cam Chain truckie Trophy 1 11-14-2007 03:22 PM
Cam Chain truckie Maintenance & Workshop Talk 2 11-13-2007 04:46 PM
cam chain English_Spanner Twins Technical Talk 5 01-27-2007 01:59 PM
Cam chain has me stopped PaloAlto Maintenance & Workshop Talk 7 06-19-2006 12:22 AM
