Trident-Exhausts.comAdvanstarMotorcycleShowsMotorcycle.comBikeBandit
ShopTriumph.com
Old 02-06-2005   #1 (permalink)
I'm finishing up my valve adjustment and I elected to remove the cams instead of buying the valve tool.
Anyway...I've got the cams back in place and all the alignment marks are lined up but, the cam chain just doesn't look seated to me. I can see just a little bit of daylight between the chain and the sprocket teeth. Is this normal? I've even tapped on the top of the chain with a mallet lightly but, it doesn't seem to make a difference.
The chain is firm in place and doesn't seem like it's about to jump a tooth.
Will it seat better after an engine rotation by hand?
Thanks
Sprintguy is offline   Reply With Quote
Old 02-07-2005   #2 (permalink)
Sounds like you have it seated correctly.
Jhumphrey is offline   Reply With Quote
Cam Chain truckie Trophy 10 01-14-2008 03:41 PM
Cam Chain truckie Trophy 1 11-14-2007 02:22 PM
Cam Chain truckie Modifications & Workshop Talk 2 11-13-2007 03:46 PM
cam chain English_Spanner Twins Technical Talk 5 01-27-2007 12:59 PM
Cam Chain Replacement pendraig T3 Sport / Touring Forum 6 11-28-2005 09:46 AM
