Motorcycle.com
Old 12-26-2007   #11 (permalink)
Favorite Bike: 05 Sprint, Wife, & Kid
jeffro's Avatar
Other Motorcycle: Riding Mower/Aussie
Extra Motorcycle: 8 yrs old Daughter
Hose locations
Where are the two hoses? I took my tank and air box off on x-mas to replace the fouled plugs. It was a lot eaiser then I thought.
high back risers Corbin Gunfighter and lady Corbin Back rest for the Lady Frame Sliders (After a drop outside of Hooters) :( TOR can and tune M PP 2 CT tires Pazzo shorts,Stebel Horn, Homemade (OnD Style) Throttle Meister, Givi DB, 18t front
jeffro is offline   Reply With Quote
Old 12-26-2007   #12 (permalink)
Favorite Bike: 06 Sprint-Argentum Celer
oldndumb's Avatar
The hoses are item 14. The roll-over valve in the tank vent line is item 33. The other hose is the filler neck water drain.
If you remove your tank, and fail to reconnect the hoses, the bike will run but you run the risk of spilling fuel onto your engine and will spill fuel in event of a tip over.
Oldndumb
Caveat lector
Old 12-26-2007   #13 (permalink)
Favorite Bike: 06 Sprint ST ABS red
iceman's Avatar
....... here you go jeffro - the 2 vent hoses are just in behind the blue wire.You must have removed them to get your tank off.
following on from OnD said - I understand the main task for the 'rollover valve' is to stop your tank emptying out through the vent pipe if the bike ends up on its side.
Another trick is to ensure that both pipes are clear of your fairing at the bottom - so that petrol doesnt end up on your paintwork.
Grant
iceman is offline   Reply With Quote
Old 12-26-2007   #14 (permalink)
Favorite Bike: 2005 Sprint ST
3banger's Avatar
Other Motorcycle: KTM MXC 200
It sounds like the rollover valve to me. I had the same problem after I had the tank off. I decided to route the tank vent lines a little differently to tidy thing up and didn’t fully understand the point of the roller over valve. I left it sitting at a 45* angle and it sealed off the vent line, needless to say the bike ran like crap as the tank got low but ran fine one the tank was vented. Once I set the valve back vertical the problem was resolved. If you pull the valve and hose and blow through it and tip the valve you will feel just how sensitive it is and is clearly designed to block flow in both directions if it is tipped even slightly off vertical. I suspect it is also susceptible to failure due to its sensitivity.
If it ever causes me any problem again it will be removed. My dirt bike leaks gas every time it’s in a horizontal position and this is a frequent occurrence; I have yet to burst into flames.
3banger is offline   Reply With Quote
Old 12-26-2007   #15 (permalink)
jeffro's Avatar
Grant
Does it matter which hose goes in which slot on the tank ?
Old 12-26-2007   #16 (permalink)
oldndumb's Avatar
Of course it matters. I can never remember which one goes where because I put a yellow tywrap on the fuel vent line to easily identify it.
If someone doesn't do a search and direct you to the thread that discusses this, the easiest way to tell them apart is to try blowing into one of the hoses at the tank end. The water drain is always open. The fuel vent line will be closed by the check valve in that direction. Air flow in the fuel vent line is from the bottom of the hose, through the check valve, into the tank to replace displaced fuel.
What is going on Jeffro.....thought you said this stuff was easy?
The fittings on the tank can be identified by putting low air pressure (3 to 5 psi) on either of the orfices.
Oldndumb
Caveat lector
Old 12-26-2007   #17 (permalink)
CLB
The front fitting is the tank vent and should connect to the hose with the rollover valve.
The rear is the drain for the fuel cap detent and required no external valve.
CLB is offline   Reply With Quote
Old 12-26-2007   #18 (permalink)
3banger's Avatar
OK I just went out and looked, the line with the roll-over valve connects to the nipple closest to the front of the tank. This is the same port that seals into the gas gap when closed. The roll-over valve will allow the flow of air in both directions but stop flow if tipped.
Old 12-26-2007   #19 (permalink)
oldndumb's Avatar
I'm curious. How do you get a flow of air in both directions through a hose connected to a fuel tank.....especially with an inline check valve?
Oldndumb
Caveat lector
Old 12-26-2007   #20 (permalink)
Favorite Bike: All of them
Other Motorcycle: Suzuki DR 350
Exploded view drawings aren't always 100% accurate but the majority of them are if done right, if you look at the illustration it will tell you where the hoses go.
If you are still in doubt and one hose connects to the cap drain bind two pipe cleaners together or use a piece of wire and insert it into the cap drain hole, connect the drain pipe to the fitting they are sticking out of on the bottom side and the valved hose fits on the other nipple.
My other torque wrench is a hammer.
4N099 is offline   Reply With Quote
Has anyone ever fitted a Vapor on their Bonnie? SteveRocket Twins Technical Talk 15 01-21-2008 12:24 AM
What's up with this vapor lock thing? cafetbird Hinckley Classic Triples 12 10-16-2007 01:48 PM
Exhaust Vapor TBirdG Tiger Chat 7 04-25-2006 10:54 AM
TT600 excessive exhaust vapor hardboild Triumph SuperSports 6 04-15-2006 07:59 PM
Bolt Lock Helmet Lock? d2mini Twins Talk 13 04-07-2006 07:25 PM
