Replacing grips/grip warmer - Triumph Forum: Triumph Rat Motorcycle Forums
Old 01-23-2005, 11:59 PM   #1 (permalink)
I have the factory grip heaters, but can I replace the grips? I know some heaters are a sleeve type, and am hoping I can change out the stock grips. Thanks!
Mike in NY
kelticwolv is offline   Reply With Quote
Old 01-23-2005, 11:59 PM   #2 (permalink)
Mike in NY
Old 01-24-2005, 12:59 PM   #3 (permalink)
dnlwthrn's Avatar
No, the factory grip heaters are really heated grips. There is no way that I can see to remove the grips from the heater units. The biggest problem would be finding new grips that were large enough to slip over the sleeves that house the heaters.
I think the best method for heated grips that would give you the ability to change your grips is the dual star setup. I have the factory heated grips as well, and they seem to work fine. We'll have to see how they hold up during the warm weather, but for now they're great.
Dan
dnlwthrn is offline   Reply With Quote
Old 01-24-2005, 12:59 PM   #4 (permalink)
dnlwthrn's Avatar
Dan
Carb warmer Fyr Twins Technical Talk 35 12-14-2007 08:16 PM
Replacing throttle tube and grips. Fraederichs Twins Technical Talk 1 09-30-2007 04:42 PM
Grip glue for heated grips ?? Suncoast Sprint Forum 4 09-29-2006 10:54 PM
carb warmer... Troh23 Twins Technical Talk 8 08-11-2006 11:41 PM
Any Tips for Replacing Grips? MikeWS1 Sprint Forum 7 04-03-2004 10:29 PM
