That was just a test fit, I haven't installed them yet.
ABS shouldn't care what caliper is on there
I've heard the '07s have the 5/8" master cylinder, I'm hoping that's true
I've got the "having to pump it up" issue that is is common. The first couple strokes serve to move the pistons back in, then the lever firms up.
The stock brakes were fine, but so many folks here seem to rave about the 6 pots, and it's such a simple change, I figured "why not?"
I'll report back when I get them up and running
Originally Posted by Flylow
They look fantastic. A few questions...I suppose the ABS would cycle the same with any caliper, but have you tried it? Any difference? How does it feel in comparison the the stockers? Did you change out the MC too? Were you having problems, or are you just trying to upgrade? Thanks!
