Loose fitting shifter on '01 Sprint
While I had some down time last week, I pulled my shifter assembly apart and sanded some rust off the rod and re-cleared it. I've always felt the shifter was loose on the shaft, but never realized just how loose it is until then. When I was taking the bolt out, it was so loose that the shifter kicked sideways on the shaft and stripped the bolt. So, I picked up a new bolt and tightened it down pretty tight, but not too much for fear of striping it out. The shifter is still pretty loose. It has enough play in it that it will "wiggle" back and forth.
It's not a big deal considering once the bolt is in good it keeps the shifter from sliding off the shaft and the ribs in the shaft/shifter keep it all working properly but this is the first bike I've had where it was this loose. Usually you have to work to get the shifter off because it is usually pretty tight. The bike shifts fine and feels smooth, but I was just curious if anyone else has noticed this?
-Shane
Hokie (Shane)
