'06 Sprint - 18T Sprocket - GPS Readings - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Motorcycle.comNew BonnevilleMotorcycle.com Classifieds!Honda Powersports
Old 11-26-2007, 06:30 PM   #1 (permalink)
Favourite Bike: My '06 Sprint ST - C/Blue
BallaRAT_ST1050's Avatar
Just did this 'great' little upgrade on my bike
What a difference it makes:
Much better for low speed 1st & 2nd gear turning and take-offs, only an increase of about 200 rpm (at cruising speed of 4500rpm) and much better acceleration and gear changes.
$35.00 AUD for the 18 tooth sprocket, borrowed a 36mm socket and undid it with a standard 10" breaker bar (much easier to loosen nut than I was led to believe it would be)
Now I know that these speedo's are not the most accurate so I thought I'd better check it against my car GPS, after dicking around and getting it set up on the bike I went out and did some runs on the back roads.
These will obviously be in Km/h
As you can see there is a fair difference, I now work on the 10% rule
Hope this is helpful for the guys who have gone for the 18T front sprocket.
I must say, even though it throws the speedo out a bit it is still a great upgrade - performance wise
Work to Live : Live To Ride
BallaRAT_ST1050 is offline   Reply With Quote
Old 11-26-2007, 06:58 PM   #2 (permalink)
oldndumb's Avatar
Way to go!
The 18 tooth sprocket is the most performance bang for the buck that you can do. I found that it made the bike run like it should, and easier to handle during low speed maneuvers.
The 19/42 is too tall for the bike unless the majority of your riding is in 6th gear.
Oldndumb
Caveat lector
Old 11-27-2007, 09:49 AM   #3 (permalink)
Favourite Bike: My '04 Sprint-ona
RexxyPup's Avatar
Other Motorcycle: Want a 675
Extra Motorcycle: I wish!
odometer impact
More importantly, doesn't this mess with the accuracy of the odometer for your mileage and servicing?
Perhaps this is one place where a speedo healer is useful, although it appears that the Tuneboy software will allow you to adjust this in the ECU. It's just that Tuneboy is 2-3 times the price of a speedo healer
Rexx
WARNING:! Low flying Sprint-ona ahead!
Old Albums
New Albums
RexxyPup is offline   Reply With Quote
Old 11-27-2007, 11:49 AM   #4 (permalink)
Favourite Bike: 007 Phantom Sprint
Triple Ripple's Avatar
I would think that simply changing one sprocket size would change the error in the speedo readings in a more constant manner. The non-linear readings below 60 km/hr are disconcerting. (Sorry, I can't figure out how to paste the graph into the message.)
I feel the need for speed!
Triple Ripple is offline   Reply With Quote
Old 11-27-2007, 11:54 AM   #5 (permalink)
oldndumb's Avatar
Rexx
If you know of a way to install a speedo healer to fix the speedometer and odometer please share it with us. I haven't been able to figure out how to do both.
Oldndumb
Caveat lector
Old 11-27-2007, 05:09 PM   #6 (permalink)
RexxyPup's Avatar
SpeedoHealer
OnD,
I'm assuming this is for the 05- Sprints where the signal is off the output shaft as I think you have mentioned somewhere else on the forum.
If you change the gearing on such a setup, won't you screw the odo and the speedo by the same amount? hence won't a speedo healer correct both.
I assume that is why the 1050 (ThroughTuneboy Software) has an adjustment factor that you can alter.
It's only on my 955 (where they are driven from the front wheel) where the odo is +0.1% and the speedo +10% that you can't fix with the healer.
Rexx
Old Albums
New Albums
Old 11-27-2007, 05:44 PM   #7 (permalink)
oldndumb's Avatar
OnD,
Rexx
I do not have any experience with any of the speedo healers other that what I read on their web sites.
You are correct that speedometer and odometer readings are affected by the sprocket change.
The 05-07 speedometers are optimistic from the factory, but the oddometers are accurate.
The speed sensor signal is common to the circuit board. Then the input is split on the circuit board to feed the speedometer circuit and odometer circuit individually. So if you start with a speedometer with a 10% error and an accurate odometer, and apply a correction to the signal, you will end up with an accurate speedometer and odometer with a 10% error.
I believe that the Tuneboy has the ability to apply corrections to individual cells or rows.
CLB or DEcosse can explain it with more clarity and authority than I can.
Oldndumb
Caveat lector
Old 11-27-2007, 06:01 PM   #8 (permalink)
RexxyPup's Avatar
Very true but...
If you start with a very optimistic Speedo and an accurate odo, and change the gearing, you change both of them by the same error, so using a speedo healer in this circumstance will allow you to compensate for the error introduced by making the gearing change.
you will in effect be back where you started in terms of speedo and odo errors, but have different gearing. At least this way you can return your odo to the accuracy it had before the gearing change.
The only thing common across both bikes appears to be that you can't change odo independently of Speedo.
In Tuneboy there is a single field that is called the wheel speed constant that allows you to alter the figure to remove the +7% that comes from the factory, and also compensate for gearing changes. It's on p28 of the tune edit documentation
The tuneboy corrections to individual cells or rows is about altering the fueling maps etc
Rexx
Old Albums
New Albums
Old 11-27-2007, 06:05 PM   #9 (permalink)
oldndumb's Avatar
[quote=RexxyPup;883566]
I see what you are talking about and agree. I guess I have never worried about it because I don't use my speedometer, and only use the odo for maintenance periods.
Oldndumb
Caveat lector
Sprint RS - 18T front sprocket Thefallenone Sprint Forum 21 12-09-2006 11:48 PM
Anyone want an 18T sprocket? stu Twins Technical Talk 1 11-09-2006 08:06 PM
18T Sprocket Change out help MVP44 Sprint Forum 3 09-14-2006 08:24 PM
O5', 06' Sprint Owners 18T Front Sprocket Question SoCalSprint Sprint Forum 11 07-14-2006 04:19 AM
18T sprocket for 2000rs Haggis Sprint Forum 2 04-08-2005 06:15 PM
