Seat bolts - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-25-2007, 01:51 PM   #1 (permalink)
Favourite Bike: Suzuki V-Strom DL-650
Tri-oomph!'s Avatar
Other Motorcycle: Sprint ST 1050
Extra Motorcycle: I'll take a dozen!
Seat bolts
I just purchased a used 06 Sprint and I love the bike in general. But among a few other little annoying things I've found, I took the seat off the other day for the first ttime and the bolts appear to be stripped out. The bolts themselves are okay; it's the holes.
All I see is the plastic tail piece and the seat frame where the bolts go. Are there clips of some kind missing, or do the bolts thread directly into the frame? If so, they're definitely stripped out.
Is this a common problem? Is there a fix? Is it a warranty issue?
Thanks much
Tri-oomph! is offline   Reply With Quote
Old 11-25-2007, 02:58 PM   #2 (permalink)
Favourite Bike: 07 Triumph Sprint ST ABS
F4sSprintST's Avatar
THe holes have CLIP NUTS in them. Clipnuts are a cheap & easy way to provide threads, but kinda too cheap & easy, if you know what I mean.
Clip nuts can be tricky to get started, because if you push on them they bend away
They are easily and cheaply replaced, just pull them and go to a hardware store
F4sSprintST is offline   Reply With Quote
Old 11-25-2007, 03:00 PM   #3 (permalink)
Favourite Bike: 07SprintST1050ABS Tor Red
whoosh's Avatar
I think you may be mising the 2 threaded clips that clip on the frame that the seat retaining bolts fasten into.
TornadoRed07SprintST1050ABS "WhooHoo!" (In a Homer sort of voice)
whoosh is offline   Reply With Quote
Old 11-25-2007, 03:04 PM   #4 (permalink)
seat bolts
Hi NTR,
there are so many threads about the seat fixings on here its unreal. You should have a couple of threaded spring clips for the bolts to attach to, it sounds like yours are missing. When you get some new ones, bend the tabs back before fitting them as this straightens the angle of the threads and makes inserting the bolts easier. Good luck.
Ewan.
ewan is offline   Reply With Quote
Old 11-25-2007, 03:59 PM   #5 (permalink)
Tri-oomph!'s Avatar
Thanks for all of your help. The clips are definitely not there.
Old 11-25-2007, 04:40 PM   #6 (permalink)
I'd broken one of mine, so I just ran to ACE hardware and got replacments
They didn't have the exact ones, so I upgraded 1 thread size larger, with new socket bolts & washers
Note - you need to remove the rear grab rails (not the hoop over the seat) and the rear plastic
Old 11-25-2007, 04:52 PM   #7 (permalink)
oldndumb's Avatar
F4sSprint wins the initiative award today. :
Oldndumb
Caveat lector
Old 11-25-2007, 08:54 PM   #8 (permalink)
Stock parts, note I've partially stripped the threads on one of the bolts
Old 11-25-2007, 09:49 PM   #9 (permalink)
And, where they go........
Old 11-25-2007, 09:58 PM   #10 (permalink)
Favourite Bike: All of them
Other Motorcycle: Suzuki DR 350
I haven't taken mine off yet.
Can't you just replace the clip with a lock washer a flatwasher and a nut or is it too hard to get to mit der hand?
4N099 is offline   Reply With Quote
Seat bolts johnsime Twins Technical Talk 14 03-25-2007 04:31 PM
Stolen seat bolts johnsime Twins Technical Talk 8 02-18-2007 08:04 AM
Seat Bolts chewy7676 Twins Technical Talk 8 08-01-2006 08:42 AM
Seat bolts (again) Gootch Twins Talk 0 06-12-2006 04:30 PM
Seat Bolts? AllanCook Twins Talk 5 07-08-2005 05:57 PM
