Originally Posted by otter1
Hi, Just traded in my Yamaha FZ6 for a barely used (1100 miles on odometer)2006 Sprint. I have noticed the engine surging slightly when I am steadily riding between 3500 and 4500 rpms. Is this normal or do I need it checked out? Thanks for the help, I have been wanting a Sprint and finally decided to go ahead and get one.
With everything optimal (chain, clutch, and throttle free play adjustments correct) you may feel a surge in that range if you are sensitive to your machine.
If it is enough to be objectionable, get it checked out at the a dealer with a Triumph gameboy. It could be something as simple as an updated map.
Mine does it, but it is NBD.
