I have clear tubing that i use to bleed the lines. What you can see happening is as you pump, the bubbles progress down the line. then you close the screw, let up brake to get ready for the new pump, the bubbles start to float back up the line. Its a two step forward, one step back kind of thing. So just make sure you're pumping fast enough, and it will be no trouble. Don't dawdle between pumps or the bubbles float back up to the top of the bend.
