BikeBandit
Old 11-13-2007   #11 (permalink)
Favorite Bike: Sunset Red 06 Sprint ST ABS & Silver 05 Tiger
airrider03's Avatar
...Still thinking of a solution...
Obvoiusly, the flat beam is useless on a motorcycle.
The left and right headlights are round, but a flat pattern. __ __
How about rotating the beams in the brackets slightly inward (about 30 deg) to achieve a 'V' pattern \ / (not quite 30, but you get the idea)
What kind of a key or groove in the headlight mounts would limit us from trying this out?...I've never dissected the units...but winter is setting in and it's time to experiment again...
The problem is...I spend alot of time in turns, and it's getting kinda dark around here!
Stay Still, and roll the Earth beneath your wheels...
airrider03 is offline   Reply With Quote
Old 11-13-2007   #12 (permalink)
Favorite Bike: Sprint ST 06 Blue
There is a V pattern built into your projectors already. Anymore of that and you'll end up blinding oncoming traffic.
Problem is the abrupt cutoff aggrevated by the Sprint's soft front suspension causing too much dive during braking.
Nikos
Do you want to participate in an off-the-beaten-track tour of mainland Greece?
Check below for the big Sprint ST Greek Tour being organised for Spring '08
http://www.triumphrat.net/rides-events/68872-greek-bike-tour-next-spring-anybody.html
NikosR is offline   Reply With Quote
Old 11-13-2007   #13 (permalink)
airrider03's Avatar
Nikos,
My beams are flat, if anything, the right side has a hint of "V" in it, but only 10 degrees.
I'd like to see some images of others before I mount a sidecar on my Sprint (to make it useable at night) .
Here's my pattern...only 10 degrees, but I usually lean thirty average.
Maybe mines a one-off...I'm blinding the car in front at stoplights.
Old 11-13-2007   #14 (permalink)
Favorite Bike: 06 Sprint-Argentum Celer
oldndumb's Avatar
Originally Posted by airrider03 View Post
Nikos,
That is pretty much the same pattern that I got with mine after re-aiming.
Oldndumb
Caveat lector
Headlight adjustment scspeed3 Speed Triple Forum 4 03-28-2007 03:29 AM
Headlight Adjustment English_Spanner Twins Technical Talk 10 10-08-2006 01:22 PM
Headlight adjustment madtowner Twins Technical Talk 10 07-06-2006 11:21 AM
Headlight adjustment dickieshep Sprint Forum 2 05-12-2006 09:48 AM
Headlight adjustment Swiss-Tony Speed Triple Forum 0 05-09-2006 01:34 AM
