Really Chuffed!
I've had my Sprint 1050 for eighteen months. I already change the oil and filter every 3000 miles and for a while I've wanted to replace the bleed nipples with Speedbleeders. Always kept putting it off, but today I bit the bullet. Whipped the brake pads out, took the calipers off to clean them up (they do get crappy).
All this was the easy bit. Then it was time to change those bleed screws. As it happened, it was straightforward. Although I got the second Speedbleeder installed, popped the dust cap on. Then just gave the front brake leaver a couple of pumps just to seat the pads again. The dust cap flew straight off! FCUK - duff bleeder. Quickly whipped the pads out, caliper off. Off with duff Speedbleeder and on with another new one (I'm glad I bought four!). This time everything honky dorky. Decided to change the fluid as well (it probably didn't need it).
I'll give credit to the Speedbleeders, they make bleeding the front brakes a doddle. Everything back on and cleaned up. Decided to cable tie the front brake leaver back for the night and hopefully everythings rock solid in the morning.
I'm sure everything will be fine. If everythings OK in the morning I'll be really chuffed - another maintenance job that doesn't need the shop to do.
My next maintenance goals will be plugs and air filter.
I'd just like to say "Thanks" to the posts throughout the Sprint forum - they bolstered my confidence to get on and do this bit of work (even though it probably didn't really need doing just yet). Next time, I won't have any reservations about doing it.
Cheers,
Graham
