Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 11-08-2007   #1 (permalink)
snshampton's Avatar
Help on fuel light
Hi guys,I am a new sprint owner.Well its a 99 but its new to me.I sold my 03 Bonneville America for this jewel,its loaded and in great condition.anyway on with my question....when the key is turned to the on position,should the low fuel light come on?my fuel gauge does not work and i would like to have some way of knowing when i am getting low on fuel.I ran out of gas the other day waiting for the light to come on.so when i got home i had a look at the bulb to see if it was burnt and it was.what came out of the socket was a 14v 3w, if my eyes read it correctly.so i put a 14v back in it.now i am very low on fuel and no illumination yet. Thanks in advance for any replies.
snshampton is offline   Reply With Quote
Old 11-08-2007   #2 (permalink)
GJJ
Favorite Bike: 2001 BRG Sprint ST 955i
GJJ's Avatar
Other Motorcycle: 65 Austin Cooper "S"
My low fuel light came on also when I recently took the tank off of my 01. The problem turned out to be that when I put everything back together I failed to push the two prong conector located under the back side of the tank fully together.This sends a signal to the low fuel light. Pain to get at as you have to remove most of the fairing, seat and then tank to see if it is connected. Simple fix though and first place I would look.
I know this is the reverse of your problem, but a place to start.
Gary
Outside of a dog, man's best friend is a book. Inside of a dog it is to dark to read.
GJJ is offline   Reply With Quote
Old 11-09-2007   #3 (permalink)
Favorite Bike: ST 955 for now.....
GONE14S's Avatar
There is a quick way to check to see if the fuel light is working.
Remove the tank. Take the two wire plug and jumper it wire from one pin to the other, wiring harness side. The light should come on. When you remove the wire it should go off. This of course is done with the key in the on pos.
You can also do this for the fuel gage at the big plug where the fuel lines connect in the tank. When you jumper wire the fuel gage wire, again key on,the fuel gage should go all the way to full reading if the gage is working.
If it does then you have a bad sending unit in the tank.
The sending unit in the tank will cause the fuel gage and the fuel light not to work.
Kurt
01 Sprint ST955
British racing green.
"To show fear is to lose control, To lose control is to make a mistake, To make a mistake is to lose the game. "
GONE14S is offline   Reply With Quote
Old 11-09-2007   #4 (permalink)
snshampton's Avatar
thanks! i will give it a shot tomorrow.
Old 11-10-2007   #5 (permalink)
Favorite Bike: 2000 Sprint ST
Other Motorcycle: 1974 Triumph Bonneville
Extra Motorcycle: 1973 Triumph Tiger
snshampton -
Let us know what you found out.
roadduster2
just do it
roadduster2 is offline   Reply With Quote
Old 11-10-2007   #6 (permalink)
GONE14S's Avatar
You could pull the sending unit out and work the float assem. up and down while pluged into the bike ,with the key on and see if if the gage moves.
When you do this your looking to see if the float is sticking.
When the float is all the way down the fuel light should come on. When all the way up the gage should read full. Check to see if there are any broken wires on the sending unit assem. OR if the is any junk or corr.
You can do a OHM's-Volts test while you have it out also.
Kurt
01 Sprint ST955
Old 11-17-2007   #7 (permalink)
snshampton's Avatar
well it was the light that was not in all the way.And yes it does come on when you turn on the key and goes out when the motor starts.I still don't think the fuel gauge works.i took out the sending unit and messed with it ,it looked fine.
Fuel Gauge Low Fuel Light problem any ideas ? CYNCRZR Sprint Forum 4 06-09-2007 11:36 PM
o7' tiger fuel low fuel light spezz1 Tiger Chat 5 06-04-2007 09:54 PM
Fuel Gauge OK, Low-Fuel light intermittent andy-D Tiger Chat 3 11-16-2006 04:46 PM
Intermittent Fault - Engine warning light & Fuel light Tassie_Tiger Tiger Chat 4 06-13-2006 08:58 AM
Engine light and erattic low fuel warning light guy71 Daytona Deliberations 12 04-17-2006 08:18 AM
