Motorcycle.comAdvanstarMotorcycleShowsTrident-Exhausts.com
Old 11-06-2007   #1 (permalink)
Favorite Bike: 06 Caspian Blue Sprint ST
TattooedRedHead's Avatar
Other Motorcycle: I wish- Daytona 675
Extra Motorcycle: I pray- Street Triple R
Powerbronze Tail Tidy Install...
Just teaser text tonight guys, I haven't finished my write up of the install or the custom wiring and box I installed to hold all the wiring.
Bought a ABS project box from radio shack and mounted it under the tail tidy, heat shrink wrapped most of the wiring and kept the stock plugs instead of cutting them off.
I also have the Powerbronze turn signals which DO NOT attach directly to the stock plugs, hence my cutting, and reattachment of the stock plugs to the Powerbronze products.
Pics and a full write up on the install when the project is done.
--Kory
"I'd rather be riding my motorcycle thinking about God than sitting in church thinking about my motorcycle"
Looking for a flush cowl for your '05+ Sprint ST?
http://ssersedvs.lw-s13.sserv.de/hau...e_modelle.html
TattooedRedHead is offline   Reply With Quote
Old 11-06-2007   #2 (permalink)
ant2812's Avatar
Question
what about some thing like this for an idea.
Sorry about thye blurry photo's but I am sure you get the idea!!!!
Anthony.
ant2812 is offline   Reply With Quote
Old 11-06-2007   #3 (permalink)
Favorite Bike: 05 Sprint 1050
WVtriple's Avatar
Other Motorcycle: 2007.5 Aprilia RSV-R
Hey Red, can you still use the stock tail lamp?? When I bring up the powerbronze web page, the tidy tail for our Sprints (05-07) has a different tail lamp setup, which frankly I don't care for. No real need to answer since your pics will be up soon enough.
WVtriple is offline   Reply With Quote
Old 11-06-2007   #4 (permalink)
Favorite Bike: Black '07 Sprint ST
kkleinert's Avatar
+1 I was just thinking the same thing.
kkleinert is offline   Reply With Quote
Old 11-06-2007   #5 (permalink)
Which tail lamp? The BRAKE LIGHT? or the little lamp that lights the license plate?
--Kory
Old 11-06-2007   #6 (permalink)
Favorite Bike: My beautiful black 07 Spr
denman13's Avatar
Other Motorcycle: 84 Kawasaki Spectre (red
Extra Motorcycle: KTM Penton 125 (dirt) now
The answer to either of those is yes, you do not have to change the tail or plate light. However, the plate light is a tight fit so you have to use a little pressure to get it in there but it works fine. I did not have to cut any wiring or use different connectors and I too bought an ABS project box (2"X4") and used the rear-set bolt holes to mount it. This means that I'd have to move the box if I want to put the bags on because I have the Tail Tidy in the lower position, but I don't really use the bags much. I did have to file out most of the holes a little because things didn't quite fit right but it was an easy fix. Also, depending on where you live, the license plate mounting holes are set up for UK plates so you'll have to drill a couple of new holes in your plate to get them on. Overall, it looks so much better than the stock mud-flap that comes on the bike.
Your enemy is never a villain in his own eyes.
Never miss a good opportunity to shut up. - Will Rogers
denman13 is offline   Reply With Quote
Old 11-06-2007   #7 (permalink)
denman13's Avatar
Ooops, I just realized that you guys are talking about the PowerBronze tidy and I have the R&G one. So much of what I just said may not be accurate. I have other PowerBronze parts on the bike and I guess I'm just getting old enough that I can't remember which is which any more.
Old 11-06-2007   #8 (permalink)
WVtriple's Avatar
Yes, to the brake light, no to the license plate illuminator. The brake light is now a small oval shaped light according to the pics on the web site, I would like to be a to stay with the stock lamp. Actually the pics that ant2812 put up are what I'm looking for.
Old 11-06-2007   #9 (permalink)
denman13's Avatar
Oddly enough, the PowerBronze and the R&G look almost identical. I didn't have to change any of the lights on mine but like I said, I did have to file out the wire holes a bit to get the couplings through. If the PB tidy means you have to change lamps and you don't want to do that, you might want to try the R&G one. I ordered mine direct and it showed up at my door in about a week.
Old 11-06-2007   #10 (permalink)
Please go here for a full walk through of the installation:
Click Me
--Kory
Anyone use a Tail Tidy? Calliway Sprint Forum 24 01-03-2008 12:16 AM
Powerbronze Tail Tidy Installation Walk Through. TattooedRedHead Sprint Forum 6 11-07-2007 04:01 AM
Tail Tidy Shaunlee Speed Triple Forum 6 10-23-2007 03:46 PM
Advice on Powerbronze Hugger Install? Yimm Sprint Forum 6 02-15-2007 05:08 AM
TAIL TIDY AVAILABLE SOON BUCKET Speed Triple Forum 2 03-07-2006 06:40 PM
