Ignition switch failure
My ignition switch went out on my 2000 sprint RS. In hindsight I think I know what happened. When it went out, I could wiggle the wire bundle at the base of the ignition switch and the bike would come alive, then die, then come alive, then die. Hard to ride holding that wire perfectly still..hahaha.
Well, a couple years ago I was having trouble with the throttle um throttling when I was full lock right, so I shoved the throttle cable under the ignition switch, instead of in front of the ignition switch like it was. In hind sight I think the throttle cable was fighting with the ignition switch wire bundle when I shoved the cable under the ignition switch..oops. Shoulda figured out a better routing for the throttle cable. Oh well. My mechanic is fixing it since he's replacing the valves too, but that's another post for later.
