BikeBandit
Old 10-22-2007   #1 (permalink)
Immoderate Moderator
Favorite Bike: '04 Sprint RS
KitNYC's Avatar
Other Motorcycle: Dead '96 Trident
Extra Motorcycle: Dead '76 KZ400
Sprocket question
Sorry if it's been asked before, but I couldn't find an answer in the forum & the shop manual is utterly infuriating in its obfuscation of information on the front sprocket....
On my old 885 bike, there was oil under the sprocket cover & seals & gaskets had to be replaced whenever it was removed. Is that also the case with my '04 955, or can I just pull the cover, swap the sprockets, & put it back on?
Thanks,
-Kit
Old 10-22-2007   #2 (permalink)
The cover is secured with 8mm bolts, and can be removed to reveal the sprocket. There is no need to worry about oil or gaskets. You will need a 36mm socket and considerable leverage to remove the sprocket nut.
I've never encountered a set-up like you describe.How is the oil sealed where the chain enters the housing? Is it all in an oil bath like very old bicycles?
Dusty is offline   Reply With Quote
Old 10-22-2007   #3 (permalink)
KitNYC's Avatar
Thanks, Dusty. That's what it looked like from the outside, but I've learned not to pop covers off without checking about gaskets & such first....
Here's a picture of an 885 motor:
The sprocket cover is in the lower right of the photo. Note that the oil filler is part of the cover, & that the clutch release cylinder attaches to it as well. So no, the chain is not in an oil bath. The part is just far more complex than any sprocket cover ever needs to be.
Cheers,
-Kit
Old 10-23-2007   #4 (permalink)
Thanks, Kit,
I've no experience of the885cc motor. At least Triumph seem to have made things simpler with that redesign.Good luck with the sprocket change. Most folks on here, including me, seem to prefer the 18T for the improved low end grunt and acceleration. I presume that's what you're doing too.
front sprocket question ditchrat69 Triumph SuperSports 2 05-09-2007 09:34 AM
'98 T595 sprocket question and a random question rotten03 Daytona Deliberations 12 03-25-2007 05:51 PM
18 Tooth Sprocket question kcnlisa Twins Technical Talk 24 09-03-2006 11:44 AM
18t Sprocket Question. upnet Sprint Forum 12 08-21-2006 08:42 PM
front sprocket question NVBOOZEFIGHTER Daytona Deliberations 13 06-15-2006 06:02 PM
