Motorcycle.com
Old 10-20-2007   #1 (permalink)
Favorite Bike: 2002 Sprint ST
deller4210's Avatar
Question Rear Cush drive on the 02 ST
Cush drive on an 02 Sprint ST, should it be tight enough not to feel play when moving the rear sprocket by hand, or should you have some slack there?
deller4210 is offline   Reply With Quote
Old 10-21-2007   #2 (permalink)
Favorite Bike: 2002 RS
Stlakid's Avatar
Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
There should be no movement. In 2002 there was a design change on the cush drive rubber inserts. You may still have the old style in there.
My Photo Album
Stlakid is offline   Reply With Quote
Old 10-21-2007   #3 (permalink)
deller4210's Avatar
Question Cush drive
Stlakid, have you had to change your cush drive rubber inserts on you “02” RS as of yet? I have 35,000 miles on my ST and just wondering what might be the average wear rate for this drive?
Old 10-21-2007   #4 (permalink)
Stlakid's Avatar
No. I was lucky as my RS is a late production and already had the newer parts fitted as standard. By hand you should not get any play at all. I have 30k on mine so far and the assembly is still snug to assemble. There is no real 'pre-load' to speak of but if you have slop in the assembly by hand when you have 100+ hp on tap you would get a driveline with noticable 'snatch' to it. According to Bike Bandit they are $15.35 each and they usually quoth Triumph LIST prices to the penny. A bit expensive, but what Triumph parts are not.
Something you could check into.....
The rear hub is not made by Triumph and seems to be a bit 'universal' The rear sprocket from a 1999-2006 GSXR1000 is a perfect fit. Looking at the pictures it 'looks' as if the Suzuki cush drive rubbers are 'VERY' similar in design. At $6.37 each I would at least go to the dealer and take a good look at them.
You could put some shims in there made from an inner tube for a quick fix. Someone else here did that a while ago.
My Photo Album
Free play in rear cush drive kredge Sprint Forum 2 01-10-2008 11:22 AM
My "cush" drive speedblastr Twins Technical Talk 16 09-03-2007 05:00 PM
will a cush drive work if reversed? sweatmachine Modifications & Workshop Talk 3 02-08-2007 01:02 PM
can someone explain the "cush drive" to me? zooplancton Speed Triple Forum 6 12-08-2006 06:02 PM
More thinking out loud: Final drive question, why not Belt drive or Shaft drive? rudebwoy85 Speed Triple Forum 10 11-07-2005 09:13 PM
