when I did the RHS peg a few weeks ago, i tried it with the bracket in situ, and found 1 of 2 things will happen, you`ll either knock the pin so far through, it will fly out on the inside and you`ll loose it, or you`ll knock it out just enough to get the pivot pin out, leaving it stuck in the back, leaving you unable to knock it back in from the inside.
Also you`ll have a problem bending down, and trying see to line up the pin/groove.
but if you remove the bracket, you can grip it in soft jaws of a vice, and have a solid surface to work against when replacing the pin. more work, but easier in the end
Oh and its a awful tiny hole, which makes it even more fiddlier
P.S in the uk we call em either mills or C lock pins
I accept no responsibility for swearing, drinking, motorcycle riding or your pregnant teenage daughter.
