Here are some other things you can do to diagnose the problem.
First, REMOVE THE FUSE! Do not do anything else until you've removed the fuse.
Then, after removing the fuse, take an ohmmeter and put it between the contacts inside the power socket. If you get any conductivity at all (i.e. the meter moves even slightly) then you have an internal short, and should probably just replace the outlet.
Having never removed the plug, I don't know if it's attached to its feed line by a connector or of it's hard wired, but there's probably a connector somewhere. If the socket fails the above test, do the same test at this connector. That will isolate the problem to a given point. Your best bet is still probably to replace the bad part, because electrical parts like this are usually pretty hard to restore once they go bad.
However, you might want to try picking up some DeoxIT (try Radio Shack) and spray that into the socket. It does a pretty good job at cleaning electrical contacts, so if you have a bit of corrosion or whatever in there that's causing the short it might help.
