changing coolant - Triumph Forum: Triumph Rat Motorcycle Forums
Honda PowersportsNew BonnevilleMotorcycle.comMotorcycle.com Classifieds!
Old 09-22-2007, 12:17 AM   #1 (permalink)
Favourite Bike: 2000 Sprint RS
changing coolant
Hello all,
I recently bought a 2000 RS and I want to change the coolant on it. I've found some posts about it, but nothing concrete, so I just wanted to list what i've got so far and see if you all could fill in the blanks and/or answer the questions I have.
-Take off radiator cap and overfill cap
-Pull the hose at bottom of the radiator to drain
-reconnect hose
-fill the radiator with distilled water, then run to operating temp(#1 with or without the caps on??)
-pull the hose and drain(#2 hot or wait until the water is cold??), keep repeating until the water is clear
-reconnect hose, fill radiator to top with coolant(#3 with air bubble drain plug out??)
-fill overfill tank
I think thats it, mainly those 3 questions. Thanks in advance!
fergman is offline   Reply With Quote
Old 09-22-2007, 12:38 AM   #2 (permalink)
Favourite Bike: '03 Sprint RS
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Extra Motorcycle: CB400SF, 4 x DT175, MX80
Welcome to the forum fergman
For what it's worth
I normally drain the system by removing the bottom hose, flush the system with a garden hose (not distilled water) and push out the coolant, reconnect the hose and repreat, then refill with tap water and coolant.
Then I run the motor without the caps on and top up the main system and then when that is full top up the overflow tank.
The main points are
Complete drain, completely fill and recheck
Our water quality it pretty good and I am not sure what yours is like..
Good luck.
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
Old 09-22-2007, 01:34 AM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Welcome
Hi fergman,
welcome to Triumphrat.net and the Sprint forum.
Seems like my mate Steve has got you sorted on this one.............just as well 'cos I wouldn't know.
If you want to know about tyres I might know something.....maybe:
DaveM:
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 09-22-2007, 10:52 AM   #4 (permalink)
oldndumb's Avatar
This is how I did it on an 05 and an 06. I do not know if the 2000 RS is the same. If not, the details may not be alike, but the principle should be the same:
  • Remove radiator pressure cap
  • Release radiator bleed screw
  • Release water pump bottom hose
  • Drain
Refilling
  • Reconnect bottom hose
  • Add coolant through radiator filler until full. If the system is filled correctly and fully, there will be coolant visible at the bleed screw and in the filler opening.
  • If there is no coolant at the bleed screw, attach a length of tubing to the bleed screw spigot and pour coolant into the bleed screw side of the radiator.
  • If needed, top off the system through the filler and reinstall the pressure cap.
  • Start the bike and let it run to allow trapped air to be expelled.
  • Stop the engine, check for leaks, and refill the radiator as necessary.
  • Refit the pressure cap.
  • Check the expansion tank level and top off as necessary.
I've done a coolant change on two of these bikes and in both cases got a coolant flow at the bleed screw and did not have to pour coolant into the bleed screw opening.
Since your bike is a 2000, you might want to consider replacing your hoses if they are over three years old.
Oldndumb
Caveat lector
changing coolant birdman Speed Triple Forum 4 03-18-2007 02:38 PM
Changing coolant Buhlit-Tueth Sprint Forum 7 05-25-2006 05:04 PM
Coolant changing mathbeak Maintenance & Workshop Talk 1 04-27-2006 07:57 PM
changing coolant punisher Triumph SuperSports 9 03-14-2005 03:22 PM
Changing coolant/antifreeze Sprint Forum 1 01-24-2004 06:44 PM
