Old 09-12-2007   #1 (permalink)
Favorite Bike: '03 Sprint RS
steventhechef's Avatar
Warped front disc - advice needed..
I have just come back from the local motorbike mechanic - not Triumph - and he confirms what I thought, that I have a warped front disc on my 03 Sprint RS.
I got a second opinion from another motorbike mechanic just to confirm the worse case scenario.
I have already pulled the calipers off, exercised the the pistons and sprayed them with Motul disc brake cleaner and then reassembled them with no noticeable difference.
Bugger there goes the cheap option!
The symptoms are pulsing brake lever
1) at low speed - feels like in, out, in, out, without the associated pleasure!
2) at high speed - jump on the brakes / head shake (back and forth) unless I brake steadily and then it is OK with just the pulsing.
It is more annoying as opposed to down right dangerous.. I have lived with it for a few weeks now and it just bugs me not being right.
One guy tells me that I should replace the (slightly) warped one and the other guys says that I should "always" do both and likens the discs to brake pads. You must always do both!!
It is "only" $250 AUD (Metalgear) for each one - $600 for both - fitted but I am not the sort to spend money just because someones says I need to!!
Any advice from my learned colleagues???? Help is what I need..
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
Last edited by steventhechef : 09-12-2007 at 03:35 AM. Reason: Illiteracy and I am an idiot - but I can't help that - even with spellcheck!
steventhechef is online now   Reply With Quote
Old 09-12-2007   #2 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
HI Steve
Hi mate,
I don't know........... but I have to visit the dealer to pick up some small expensive item which I shall not discuss here incase I start another upsetting thread.
I'll ask the mechanics there tomorrow and tell you what they say, I'll call you on your bat phone. The guys all know me well. (uno tyres and stuff)
I had them all rumudging through their tool boxes today in the vain hope they might have had one of those small expensive items I could snavell for free!
I hope you can get a cheap fix for your pulse. Have you tried a disprin?
DaveM
DaveM is online now   Reply With Quote
Old 09-12-2007   #3 (permalink)
Hi Dave and thanks for the reply.
Disprin!! I have Leonie on Mogadon as she hates me spending money on the bike!!
steventhechef
Old 09-12-2007   #4 (permalink)
Favorite Bike: Silver Sprint 06
Hello all,
A friend who has an Aprillia Falco had this happen just as you describe. He had the Chain Gang man provide replacement rotors for both discs with a slight wave pattern. The metal is slightly different but the brakes work much better, with better and more predictable initial grab and then a stronger feel. Not sure of actual braking distances but the mate says it feels heaps better. The Chain Gang man seems to know his stuff and it is probably worth talking to him.
I caused the discs on my 01 Sprint to warp which was caused by some really strong and prolonged braking and with sticky calipers. One disc warped such that was a consistant run out from the inner circle to the outer circle of about 2mm. Didn't pulse but the braking effort was severly impacted. Interestingly I traded it shortly later and explained this to the dealer, being an honest person, and as the discs were not measurably worn in thickness he was satisfied to issue a road worthy certificate. The discs were stuffed though.
Let us know what you do.
Cheers, Simmo
Ride it while you can.
Simmo is offline   Reply With Quote
Old 09-12-2007   #5 (permalink)
Favorite Bike: 06 Sprint-Argentum Celer
oldndumb's Avatar
FWIW, the shop manual has a warning which says that discs must always be renewed in pairs even if one of a pair is servicable.
If the good disc is approaching the wear limit, I would replace both. Otherwise, you could opt for one and then do a series of careful test rides and brake tests. Probably wouldn't hurt to get a second evaluation and have an experienced rider evaluate the braking performance also.
What is a "Mogadon"?
Oldndumb
Caveat lector
Old 09-12-2007   #6 (permalink)
Favorite Bike: Sprint ST!
Grae_ST's Avatar
OnD
Mogadon is a powerful hypnotic drug, possessing strong sedative, anticonvulsant, and muscle relaxant....
As for the disks, I would personally change the pair, I won't take any chances with brakes. EBC have contour/wave rotors for the Sprint's.
Cheers, G
I may not have gone where I intended to go, but I think I have ended up where I intended to be.
- Douglas Adams
Grae_ST is offline   Reply With Quote
Old 09-12-2007   #7 (permalink)
oldndumb's Avatar
Originally Posted by Grae_ST View Post
OnD
Cheers, G
I would probably change both also and opt for the EBCs.
Where was this Mogadon stuff when I needed it? I could have used it with my first two wives.
Oldndumb
Caveat lector
Old 09-12-2007   #8 (permalink)
Favorite Bike: Triumph Sprint 1050
Smile
Steve,
I was just talking to someone this week re warped disks, he reckoned that he could wark a disc quite quickly if he wanted to ( he does race bikes) by lots of very short sharp and hard breaking, effecively you are heating up part of the disc or at very best having varying temps arround the disc.
Conversely he also claims to be able to take the warp out, over a period of time, be using good braking tecniques.
It may be a load of c*** but I would give it a go, no harm done.
Basically for the next few months try not to have short bursts, hold the breaking longer and try to get some heat into the whole of the disc this way as the disc heats and cools evenly localised stress points are taken out.
If you try it please let me know if it works.
Cheers Gavinb.
He who dies with the most toys wins.
gavinb is offline   Reply With Quote
Old 09-12-2007   #9 (permalink)
Favorite Bike: '03 Sprint ST
Steve, assuming you've a pile of miles on the rotors, I'd suggest you change them both.
With all the things to worry about while at speed, you sure don't want "iffy" brakes in the mix.
AFA a warped rotor staightening itself, I'd think it'd be like trying to smooth out a sheet of Aluminum foil after you creased it.
The way I see it, you've three options: New OEM (yuk!), eBay used (dicey), or aftermarket. I'd go with a set of waves and new pads. Make sure you get the ones for the Southern Hemisphere!
pushr0d is offline   Reply With Quote
Old 09-12-2007   #10 (permalink)
oldndumb's Avatar
I think the International Universal Spoliative Act requires vendors to only ship coriolis compliant parts to each hemisphere. But, it is always best to be safe and specify which hemisphere you are in when ordering.
Oldndumb
Caveat lector
Is SM dual disc brake needed? HumpedZebra Twins Technical Talk 9 10-10-2007 09:50 PM
Another warped disc/rotor Nursey Twins Technical Talk 4 08-07-2007 08:23 AM
Rear Disc Needed fuzzdevil Twins Technical Talk 2 02-16-2007 09:34 PM
daytona rear disc warped dean68uk Daytona Deliberations 5 05-17-2006 03:30 PM
