BikeBandit
Old 08-27-2007   #1 (permalink)
Favorite Bike: 2006 Triumph Sprint ST
ricster's Avatar
removing rear tire
If I put my sprint st in gear...will that be enough to spin the rear nut off or will I have to apply the brake?
Ricster
ricster is offline   Reply With Quote
Old 08-27-2007   #2 (permalink)
Favorite Bike: 06 Sprint-Argentum Celer
oldndumb's Avatar
IMO it is easier on the bike to use the brake only.
Don't know what else to say because I always use an impact wrench.
Oldndumb
Caveat lector
Old 08-27-2007   #3 (permalink)
ricster's Avatar
I will see if I can apply the brake at the same time I can brake loose the bolt.
Thanks Oldndumb
Old 08-27-2007   #4 (permalink)
Favorite Bike: '03 Sprint ST - Silvah
SEAsprintah's Avatar
I do both. Because it's awkward to apply brake and torque the nut at the same time having it in gear allows me to not reef on the brake as much. If its at the proper torque its not too bad. If it's over torqued you'll need a pipe extension.
SEAsprintah is offline   Reply With Quote
Old 08-27-2007   #5 (permalink)
ricster's Avatar
I just tried getting that nut off...f### I cant get a good enough grip on the nut with my 46mm socket...it seems the socket wont go deep enough...looks like I need an impact gun to get it off..and I dont have one near by....looks like I will have to ride the bike to the dealer if I can make it while losing air pressure. Hope I can make it.
Old 08-27-2007   #6 (permalink)
Favorite Bike: Sunset Red 06 Sprint ST ABS & Silver 05 Tiger
airrider03's Avatar
I also use the brake when removing the nut.
The big question comes up when you put it back on...after being torqued, will the nut end up in the same position so the clip easily slips thru the hole?
I haven't tried that yet, so I just screw it on 'till the (2nd) hole lines up.
Stay Still, and roll the Earth beneath your wheels...
airrider03 is offline   Reply With Quote
Old 08-27-2007   #7 (permalink)
airrider03's Avatar
What happened? You got a leak?
Old 08-27-2007   #8 (permalink)
Yes you can ricster. I'm not sure, because I haven't had too much of a problem (other than almost busting a vein in my head because the nut was over torqued)--but it's probably like lifting the bike onto the centerstand. Do it the wrong way, it's almost impossible, the right way is trouble free.
Hold the socket tight to the nut with your right. Press down on breaker bar with left. Bike in gear (I go for second). Right foot on brake. Left foot holding you up.
It's just like playing twister.
Torque it back on properly and the holes line up.
(leave it on sidestand till nut is loose, but roll it forward till you can't anymore)
Old 08-27-2007   #9 (permalink)
ricster's Avatar
see your pm steve (airrider)
Old 08-27-2007   #10 (permalink)
Favorite Bike: My beautiful black 07 Spr
denman13's Avatar
Other Motorcycle: 84 Kawasaki Spectre (red
Extra Motorcycle: KTM Penton 125 (dirt) now
Aww just when it's getting good, you go all PM on us. Must have been cops, hookers and large quantities of illegal substances crossing several borders involved.
Your enemy is never a villain in his own eyes.
Never miss a good opportunity to shut up. - Will Rogers
denman13 is offline   Reply With Quote
Removing rear tire of 2007 Bonnie t3knoid Twins Technical Talk 9 07-24-2007 07:01 PM
Removing the rear wheel blinker Speed Triple Forum 16 07-27-2006 04:16 PM
Rear Light Kit after removing rear fender TonyThruxton Club Cafe 2 05-15-2006 08:47 AM
Removing the front tire rkx Sprint Forum 6 04-20-2006 10:30 AM
Removing Tire from Rim faffyface Twins Talk 7 08-17-2005 08:19 PM
