Originally Posted by oldndumb
You can walk into just about any Autozone or affiliate store and get the same thing for $4.95. Where are you buying your filters?
Good question. I hadn't even considered where to get filters and oil yet. If I can't get the present filter off, there's no point. :-)
All I knew is this isn't quite as straighforward as my other bikes, and I needed a particular socket that will get in there. I'm still trying to find out what that is. The shop manual gives a Triumph part number, but no description that would help me identify a suitable aftermarket tool. In fact, the manual doesn't specify what filter to use, either. That would help in buying stuff *before* I start fiddling...
Anyone able to fill me in?
Thanks!
