On my old bike 2001, I had a ZG double bubble. I am 6'4". I tried it mainly to try and reduce 'upper body wobble' which the standard broad screen seemed to promote. The DB was great for higher speed work and enabled getting the head down. For normal road riding when the weather was calm it gave a better ride but if there were crosswinds and traffic buffeting I reckon it was a bit worse nthan standard. It ended up breaking into thousands of pieces when a bird tried to fly throgh it. I just put the standard one back on and traded up to an 06 model. The screen on the 06 is narrower and I havent yet found the need to change, whether it be normal road riding, long trips, or a track day. I need to wear ear plugs and I think I might look at a 'helment curtain' thingy that I have seen which slips on around the base of the helment and provides air control into the helment from below, looks like it might stop a bit of noise as well.
Cheers, Simmo
Ride it while you can.
