Old 08-23-2007   #1 (permalink)
Exclamation High Handlebar heads up-part numbers
Hi All,
Recently purchased an 06 ST ABS with 600 miles. Great bike and a great deal
from a guy who didn't have time to ride. (young family) Anyway, I knew my older back would appreciate the higher handlebar kit so I called the dealer with the part number from Triumph's website. Kit arrived, tore bike to pieces, installed bars clutch cable etc, went to put brake line on and discovered the fitting at the splitter(left side frame rail) was a 45 degree fitting instead of the straight one on the original line. Did a little investigating and realized the part numbers on Triumph's site are switched between the ABS and non-ABS versions. I ordered the 022 kit, the sticker on the box ends in 022, but the description says it non-ABS. My fault for not double-checking. Called customer service, Peter is going to try and find me a line. Hopefully can get it sorted out soon, planning on a trip to New Hampshire Tuesday after labour day.:
banditzed is offline   Reply With Quote
Bearing part numbers kc5deb Sprint Forum 6 01-20-2008 09:57 PM
Part numbers seumas T3 Sport / Touring Forum 0 08-05-2007 11:27 AM
Part numbers ... ErricZTT Daytona Deliberations 9 05-10-2006 07:32 AM
Part Numbers and finding them Modifications & Workshop Talk 2 01-13-2005 05:53 PM
How to check part numbers: is it right? Sprint Forum 2 12-12-2004 07:38 PM
