Old 08-22-2007   #1 (permalink)
Favorite Bike: 2006 Sprint ST
thinkjerm's Avatar
Riding with my friend
who rides a GSXR 750, and he went down. He seems to be ok, only minor scrapes and muscle ache, but the bike took a beating. The question i have is that he had swingarm spools put on his bike for easy maintanence and it looks like that is what caused him to fall. Are you supposed to take swingarm spools off when you go riding? The swingarm spool has a solid chunk taken out of the bottom from what looks like the initial impact and then it is scraped diagonally for the rest of the slide. I am just wondering is it possible that the spool hit the ground causing his rear tire to come out from under him or should something else hit first.
thinkjerm is offline   Reply With Quote
Old 08-22-2007   #2 (permalink)
Favorite Bike: 2002 Sprint ST
deller4210's Avatar
Smile Suzuki down!
thinkjerm, if you are referring to the type of spool I'm thinking of they double as protection during a slide. These would be mounted very near the rear axle if not on it and allow the use of a pivot bar to raise the rear tire off the ground. Do you know the manufacture of the spools? Oh, and tell your friend to replace that thing with a good British product!
deller4210 is offline   Reply With Quote
Old 08-22-2007   #3 (permalink)
thinkjerm's Avatar
These are the sliders that were used http://street.parts-unlimited.com/44/564/4026547
I will post some pics of the bike shortly.
Old 08-23-2007   #4 (permalink)
kptaylor's Avatar
He would have to have had the bike leaned way the hell over for these to lever up the rear tire. If you read the link you posted it says they act as sliders for the swingarm, too.
kptaylor is offline   Reply With Quote
Old 08-23-2007   #5 (permalink)
thinkjerm's Avatar
The pics
Here are the pictures of the bike http://picasaweb.google.com/thinkjerm/Suzuki
I believe he fell around where the car is in the turn of the google map image. The bike was near the end of the turn when i went back for him.
Old 08-23-2007   #6 (permalink)
I ride the same bike
with similar spools. My 750 is my track bike and there is just no way that this is what caused the crash.
No, your not supposed to take them off. Since the bike is broken anyway and if you want to experiment, lay the bike on its side and try to get those spools to touch before any other part of the bike. Make sure the tires stay on the ground too. Its gonna touch a pipe or peg first and then run out of contact patch long before those spools touch.
Cheers
Mike
How fast can you slow?
GnuPG ID:BD1D95AD
mhanson is offline   Reply With Quote
Old 08-23-2007   #7 (permalink)
Favorite Bike: My beautiful black 07 Spr
denman13's Avatar
Other Motorcycle: 84 Kawasaki Spectre (red
Extra Motorcycle: KTM Penton 125 (dirt) now
Sure, you can see that he would easily peg out before hitting the spools. By the looks of it if you were able to reach the spools in a lean you'd be riding on the rims. I would have to agree with everyone that the spools did not cause the crash and may have saved the swing arm and rear axle from any more damage than it suffered.
Most importantly, glad to hear he's OK.
Your enemy is never a villain in his own eyes.
Never miss a good opportunity to shut up. - Will Rogers
denman13 is offline   Reply With Quote
Old 08-23-2007   #8 (permalink)
Favorite Bike: 2001 Sprint St
MVP44's Avatar
Other Motorcycle: 2003 GSXR 1000
Ask your friend if he remembers feeling what was giving way first - did he feel the front pushing or did he feel the rear slide. He may not have noticed, but it could help figure out the cause. If your friend is a racer type perhaps he pushed the trail braking a little to far into the turn and buckled the front - one of the most frequent low sides on the track. Or it just could have been dumb luck and his front wheel hit some road kill remnants and caused the slide.
MVP44 is offline   Reply With Quote
Old 08-23-2007   #9 (permalink)
Favorite Bike: 2006 Triumph Sprint ST
ricster's Avatar
I fully agree with Mhanson...no way would the spools cause the crash, you will lose contact patch way before that!
ricster is offline   Reply With Quote
Old 08-23-2007   #10 (permalink)
Favorite Bike: '01 Sprint RS
norcaltriumph's Avatar
Other Motorcycle: '95 Ducati 900SS/CR
My guess...
would be that there was either some loose debris on the ramp or maybe just an accumulation of oil from the 1000's of cars that use that ramp every day. Ironically, my roommate from years past wrecked his Ducati on a freeway on-ramp/cloverleaf. He low-sided after down-shifting going onto the ramp on some early morning dew that was still on the surface.
If it was the spool which hit first, then he's a superbike God, and has a potential future racing in the AMA. That would be some insane lean angle....
norcaltriumph is offline   Reply With Quote
My Bonnie is looking for a Friend Jhtjon Twins Technical Talk 15 09-07-2007 12:00 PM
My Old Friend Sheepdog Twins Talk 4 03-24-2007 12:40 PM
I have this friend and......... redwhiteblue Speed Triple Forum 25 02-19-2006 11:56 PM
Fairweather friend? Dukester Twins Talk 6 02-07-2006 12:31 AM
Funeral for a friend brittour95 Trophy 7 02-07-2005 05:40 PM
