I used an external drive sender on the rear wheel with 6 magnets giving pulse count of 6 per rev. The Sprint has I believe 2.
Mine was already slow & I know Acumen does advise the slow response with low pulse count.
In the higher gears, it was fairly quick but in 1,2,3 especially,
very slow.
But it will get there. Most useful for avoiding searching for that "7th gear"
I'm going to experiment by adding a frquency mutiplier - that should improve the situation - I'll report back but it will be a few weeks
Here's a video I shot of the bike on a paddock stand -
Gear Indicator Video
you can see by tach & sound when the gear shift is & how long it takes to update the display. Notice that it updates quicker with each progressive up-shift.
Note that this was pretty low wheel speed, so would be slightly better as you go faster. However the flip side is you will have less pulses than me, so proportionately slower.
