Tight Turns
A few secrets to making the tight U Turns
When I come into the box I am in second gear, I shift my weight (counterweight) then turn my head, looking where I want to go. The important part of the headturn is to do it BEFORE you begin the turn, otherwise, you will drift left before you turn left. Headturn first, look for the entry cones, (the two cones where you entered the box), this will cause you to turn you head all the way around (Exorcist). Now as you are turning keep you head turned and scan all the way back, get to the other side as early as possible to set up for the right turn, counterbalance, look all the way back to where you started the previous (left) turn and keep you head turned, looking further back to your right. This will help in keeping the turns tight. Also, when I do it with my RS, I pull the clutch in right before the U-turn and coast through, using the friction zone to keep me moving. Without using the clutch, the torque will push you out of the box. That is my technique, it works for me and I'm sure others have different ways of doing it. And of course, we all know not to use the front brake, just the rear if necessary, using the friction zone will slow you down too.
