Originally Posted by whoosh
Anyone got any experience of this Fleaby item 330001697484
Looks cool but I'm just a bit concerned as to how bright the turn signals might be.
Thining of treating myself to this and the clear front indicators
Cheers
I try to avoid the bay so I have not looked at it.
There is more than one brand of integrated tail light available. I have used the Clearalternatives for almost a year now. The turn signal function is as bright, if not brighter, than the stock lights. The brake and tail light functions are also brighter than stock.
Part of the turn signal function failed on the first unit I installed. The customer service replacement was in my mail box in two days. That unit worked for a few months until the tail light function stopped working. I slapped it and it worked fine for about two months. I called and another one was sent quickly to me. This one has worked the longest.
Researching Clearalternatives on other forums indicated that there was a higher than normal rate of failures, but that seems to have been corrected. All of the posters agreed that their customer service was efficient and prompt.
If you go the LED route, you will need to either install resistors or a dedicated LED flasher relay.
