1050 Oil Change - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 24 (permalink) Old 08-16-2007, 07:27 PM Thread Starter
Main Motorcycle: 2015 Storm
KevB's Avatar
Other Motorcycle: R1200GS
1050 Oil Change
My 07 Sprint is due for a 5000Km oil and filter change but the owners manual doesn't say what the oil capacity is. I know what grade of oil to use but don't know how many litres to buy. I assume 4 litres will be more than enough but don't want to get caught short.
Should I also be replacing the sump plug washer?
Thanks in advance for your help.
KevB is offline
post #2 of 24 (permalink) Old 08-16-2007, 07:32 PM
Main Motorcycle: 07 Sprint ST
duckie's Avatar
4 litres is fine - but don't put it all in otherwise you will over fill it, which is not good. I think the capacity is something like 3.75 litres. And yes you should really replace the sump plug washer.
duckie is offline
post #3 of 24 (permalink) Old 08-16-2007, 07:38 PM
duckie's Avatar
Red face aaah I was wrong...
I found the specifications:
3 litres when just changing the oil
3.25 litres when changing the oil and the filter (unless you use a longer filter than standard)
duckie is offline
post #4 of 24 (permalink) Old 08-16-2007, 07:53 PM
Main Motorcycle: Blue 06 st sprint ABS
monkinwitz's Avatar
oil
Mobil 1 4T is the oil to use and i use a highflow filter hf191
TAKE NO PRISONERS
monkinwitz is offline
post #5 of 24 (permalink) Old 08-16-2007, 07:53 PM Thread Starter
KevB's Avatar
Thanks duckie, much appreciated.
KevB is offline
post #6 of 24 (permalink) Old 08-16-2007, 08:07 PM
duckie's Avatar
You're welcome!
OH NO YOU DON'T!!! :
We're not getting into another oil discussion... you naughty boy!:
duckie is offline
post #7 of 24 (permalink) Old 08-16-2007, 08:41 PM
Main Motorcycle: '06 Sprint ST ABS (Red)
TripleTime's Avatar
HALLELUJAH!!! :
To each... his own.
TripleTime is offline
post #8 of 24 (permalink) Old 08-16-2007, 09:37 PM Thread Starter
KevB's Avatar
OK, so it looks like I need to find the OIL thread. I have wondered if oil, like tyres, generates a bit of healthy debate.
KevB is offline
post #9 of 24 (permalink) Old 08-16-2007, 10:07 PM
Main Motorcycle: 06 ST, BOTM, 09-10 BOTY
oldndumb's Avatar
Other Motorcycle: 05SV1K, 2012 Ducati M1100
Do a search for 'synthetic oil'.
Oldndumb
Caveat lector
oldndumb is offline
post #10 of 24 (permalink) Old 08-17-2007, 01:32 AM
Main Motorcycle: Sprint ST 06 Blue
What I'd like to see is a combined tire, oil and chain lube thread. Should be fun....
Nikos
NikosR is offline
First oil change, gear change still clunky M2MG Speed Triple Forum 21 09-27-2012 01:01 AM
Oil change interval for the 1050 02S3 Sprint Forum 16 03-17-2007 07:18 PM
oil qty for oil & filter change??? Cheapbastard Speed Triple Forum 8 03-29-2006 09:56 AM
Oil leak->Gasket/Oil change->won't start Hinckley Classic Triples 6 11-25-2004 08:43 AM
how much oil is safe after oil change with filter shedds Hinckley Classic Triples 0 04-18-2004 07:39 PM
