Hi, Welcome to the Forum ! and Yes, they should waggle from side to side slightly. The outer disk is on bobbins with spring washers on them, to allow the disk to ,"float" on the inner rotor. It's supposed to allow for heat expansion of the rotor. The theory is that solid rotors could warp due to poor distribution of heat. But after saying that, floating rotors still can and do warp !
