Installed center stand on RS - a bolt questions
Hello there, just installed a used center stand (eBay) on my '02 RS. All is well, but I did find that the bike had a bolt already in place where the RHS of the stand would mount, with a fixed nut inside the lower header bracket. This bolt, although a 10mm size, has much coarser threads than the ones, also 10mm, supplied with the stand. I managed to find a 10mm hex bolt with the proper thread in my extensive collection of fasteners, and also a spacer to allow it to hold the sleeve and clear the outside of the stand, but it seems strange to use a different thread pitch.
I am wondering, what material is the stopper, mounted on the exhaust, made from? I used another 10mm bolt, 2 washers, and 2 nuts to rig up a temporary stop that keeps the stand parallel to the ground, with a length of heater hose split and taped onto the cross bar of the stand to cushion the crash as the stand comes up. I imagine that rubber would burn, and plastic would melt, since it is right on the header.
Anyone else with a RS made or added a center stand stop?
Thanks, Alan L. in BC
Alan L. in BC, '02 RS (Black), '69 TR6R, 3 others
