06 Sprint: no power below 3K RPM??? - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.com Classifieds!New BonnevilleOntario TourismMotorcycle.com
Old 07-31-2007, 03:02 AM   #1 (permalink)
Favourite Bike: Trying to find one
MacArrow's Avatar
Other Motorcycle: '06 Triumph ST
Extra Motorcycle: '02 Honda VFR800 (sold)
Question 06 Sprint: no power below 3K RPM???
Hi everybody!
I am kinda new here on this forum. Just got my 06 Sprint about a week ago. Now I have 450 miles on it and it looks like there is a weird problem. If I want to start moving I need to keep RPMs above 3K and gently use the clutch. In other words it acts like sport bike prepared for the track. I have service on this week and will address this question but may be someone has that kind of experience?
Thank you.
MacArrow is offline   Reply With Quote
Old 07-31-2007, 04:19 AM   #2 (permalink)
Favourite Bike: 1977 Guzzi Le Mans
Dylan's Avatar
Other Motorcycle: 2010 Speed Triple
Extra Motorcycle: 1963 Vespa GL
Hi MacArrow
That doesn't sound right at all. It's no twin but it should have lots of low end. Certainly take it up with the dealer, mine has stacks of power below 3K. You "could" pull away from just above idle if you didn't care about the engine. It should pull very strongly from 2K and like a horse from 3k.
Dylan
Dylan is offline   Reply With Quote
Old 07-31-2007, 04:34 AM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Welcome aboard
Hi MacArrow,
no it doesn't sound right but do bear in mind these engines require a bit more time than your average Japanese machine before they start to perform at their best, the gearbox is the same.
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 07-31-2007, 06:09 AM   #4 (permalink)
Favourite Bike: Sprint ST 06 Blue
I'm curious as to what you're comparing the Sprint to. A Harley?
In any case, trying to work your new bike under 3K is the worst thing you can do during run-in to this motor.
Nikos
NikosR is offline   Reply With Quote
Old 07-31-2007, 06:38 AM   #5 (permalink)
Favourite Bike: I like all my Bikes
gsbeamer's Avatar
Other Motorcycle: Sprint 1050
Extra Motorcycle: BMW R1100GS
Smile Something not right
Macarrow I bought my 06 Sprint with 1470Ks on the clock
and from day one she pulled and pulled hard from idle all the way
through the gears....maybe a good idea to bring it up at the service.
rgds gsbeamer
You can have everything you want in life, if you are happy with simple things, and Motorcycles.
gsbeamer is offline   Reply With Quote
Old 07-31-2007, 07:46 AM   #6 (permalink)
tuk
tuk's Avatar
No way that's right
rgds gsbeamer
I agree with Sean (gsbeamer), the Sprint is a very torquey machine and should pull well from down low.
Having said that, I never run it below 3000 anyway as I think that's just too low for the Sprint and most bikes - except perhaps "big ol thumpers" like Harleys. They just work better when kept in the optimum rev range.
Unlike a lot of sports bikes, the Sprint pulls well from about 3500 upwards and I certainly spend the vast majority of my time in the 3500 - 6500 rpm range. It doesn't mind a bit of a thrashing now and then though
Cheers,
Clinton
"Why not?" is a slogan for an interesting life.
tuk is offline   Reply With Quote
Old 07-31-2007, 10:18 AM   #7 (permalink)
Favourite Bike: 2006 Triumph Sprint ST
ricster's Avatar
You definetly have a problem...maybe a vacumn line undone under the tank area? Does it surge?
Ricster
ricster is offline   Reply With Quote
Old 07-31-2007, 02:38 PM   #8 (permalink)
Favourite Bike: My beautiful black 07 Spr
denman13's Avatar
Other Motorcycle: 84 Kawasaki Spectre (red
Extra Motorcycle: KTM Penton 125 (dirt) now
No bottom
MacArrow, how is the power above 3K? The bike should feel really torquey through a bit above the 7K range where the curve starts to fall off at a sharper rate. All three cylinders firing smoothly? I've powered through curves @ 2700. That was one of the things that I liked about this machine is how forgiving it is if you didn't gear down enough for a turn. The Triples do take a while longer to break in but you shouldn't be feeling a serious lack of power at low RPMs. The reason I ask if your power feels off across the board is either like ricster says, a loose vacuum tube or worst-case something like a bad/leaky head gasket (although you should be able to hear that fairly obviously.) We'll keep the positive mojo going for you that it's something simple. Nothing worse than long down-time during riding season.
Your enemy is never a villain in his own eyes.
Never miss a good opportunity to shut up. - Will Rogers
denman13 is offline   Reply With Quote
Old 07-31-2007, 06:58 PM   #9 (permalink)
MacArrow's Avatar
Unhappy
Guys,
Thank you for replies. I will definitely rise the question to the service man.
I compare it to Honda VFR800 FI VTEC.
It is kind of hard to explain the problem.
On Honda I have to problem to start moving: just need to release a clutch and I go. On Sprint the same causes engine to stall. If I want to start moving on a Sprint I need to rev engine up to 3.5-4K and maintain it there while I release the clutch. If rpm goes down below 3K it surges and it can even stall. Had a big problem to enter to the freeway yesterday because of it.
I saw the same behavior on the sport bikes prepared for the track and geared in that way: more teeth on the front and less on the rear sprocket.
As for above 3K there is a problem around 4.5K range.
I had a test ride on the demo bikes with 200 and 2000 miles on them and was exited how good and smooth the engine was. Mine was OK in the beginning (I got it with 7 miles). And I feel like it can accelerate but it does not want to.
Old 07-31-2007, 07:02 PM   #10 (permalink)
MacArrow's Avatar
denman13:
Yes, there is a sound like a something in the exhaust is not sealed. Another concern is that the frame gets hot. But I think it is normal for this bike.
I just wanted to add that I do not like the idea of "run like you stole it" brake in. What I do I ride like normal which means that engine is in the 3.5-6K range.
Anyway I have an appointment for this Thursday. Will post all findings then.
Idle rpm on 2006 Sprint St 1050? 96sprintrydr Sprint Forum 7 10-18-2007 12:43 PM
06 Sprint ST Question about power rider307g Sprint Forum 17 03-13-2007 12:11 AM
Power Outlet for '03 Sprint ST cricket1 Sprint Forum 2 03-15-2006 04:14 PM
Power Commander for '05 S3 and Sprint! DVS2XS Speed Triple Forum 1 06-25-2005 10:24 PM
Super 3 - low rpm no power Dave94Super3 Daytona Deliberations 19 06-11-2004 08:29 PM
