Injector cleaners? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-30-2007, 01:36 AM   #1 (permalink)
Favourite Bike: 2002 Blue Sprint ST
Injector cleaners?
Does anyone use injector additives once in while? I've got '02 Sprint and was wondering if I should add a fuel injector additive?
Two Wheeling Librarian - 2002 SprintST
PtboSprintSt is offline   Reply With Quote
Old 07-30-2007, 05:31 AM   #2 (permalink)
ST1
Newbie
Hi Ptbo
At around 10,000km my 2007 ST started running rough when idling around in first gear and would some times stall shortly after starting up.
I used some Wynn's inject-a-clean(in the recommended dose)and it fixed both problems instantly.Important not to use more than the ratio prescribed on the bottle or to use these products to often as they tend to eat the soft bits in your engine( just in case you did'nt know my friend).
Cheers ST1
ST1 is offline   Reply With Quote
Old 07-30-2007, 06:08 AM   #3 (permalink)
Super Daffy Moderator
Favourite Bike: 2011 Sprint GT 1050
DaveM's Avatar
Injector cleaner
I have used it on occasion just to make sure all is ok.
Don uses some stuff but I can't remember what it's called.
I don't do it very often though.
DaveM
My current album;
http://www.triumphrat.net/memberalbums/showgallery.php/cat/500/ppuser/2712/sl/d
My Original members album:
http://www.triumphrat.net/photogallery/v/member/album789/album810/
Two Triples are better than one :)
Old 07-30-2007, 06:15 AM   #4 (permalink)
Favourite Bike: 99 Sprint ST Jet Black
Maelstrom's Avatar
Instead of additives, use fuel of a higher Research Octane Rating (RON) regularly. This means premium fuel.
Premium fuels usually have fully synthetic additives which, according to one company "provide detergency, lubricity and corrosion protection". Find out the highest RON fuel available near you, and run a few tankfuls.
The total cost difference isn't that much. Depends on how much you love your bike!
Maelstrom is offline   Reply With Quote
Old 07-30-2007, 07:10 AM   #5 (permalink)
DaveM's Avatar
95 RON minimum as per Manual
Malestrom,
in Australia you should only be using Premium in your Sprint anyway as per the manual.
Be careful when using terms like "premium" as in the US and other countries they have different fuel ratings and names.
I personally normally use BP 98 Octane or Caltex 98 Octane.
DaveM
My current album;
Old 07-30-2007, 12:59 PM   #6 (permalink)
Favourite Bike: Mine
Green01SprintST's Avatar
Cool
More than using a premium grade fuel one should run a premium brand fuel. Here in the US, on the west coast at least, Chevron is arguably the most 'premium' brand available and has enough detergent additives in the formula that additional additives are not needed. Burning fuel from the local 7-11 or Quickie Mart, regardless of octane rating, is putting your engine at risk of excessive deposits because of a lack of an adequate detergent package. Why do you think they can sell it so cheap? Granted, a tank or 2 (or even 3) won't usually hurt but a steady diet of cheap gasoline is flirting with disaster. It just isn't worth the savings.
Proud to be a US Army veteran. AIRBORNE!
Green01SprintST is offline   Reply With Quote
Old 07-30-2007, 01:10 PM   #7 (permalink)
Favourite Bike: '01 Sprint RS
norcaltriumph's Avatar
Other Motorcycle: '95 Ducati 900SS/CR
+1 with Chevron
I always try to use Chevron in my bikes and my truck. I will occasionally throw some Techron fuel system cleaner in my truck (once a year or so). probably will do the same with my Sprint. Some have had good luck with the Seafoam cleaner, as well as Redline, and I have used BG44K in my cars before. I believe some folks were using pure Acetone as well.
norcaltriumph is offline   Reply With Quote
Old 07-30-2007, 01:21 PM   #8 (permalink)
HiVel's Avatar
Been using BP 93 and Shell V power 93 Octane almost exclusively-both seem to work great in my Speedy. Son uses those and Chevron too in his Sprint.
I add some stuff called Gumout w/REGANE occasionally to all my fleet. Seems to work great-no problems.
2007 Tiger "Old Blue"
2004 Thruxton "Big Red"
2006 Sprint ST ABS "The Blue COW"
HiVel is offline   Reply With Quote
Old 07-30-2007, 02:22 PM   #9 (permalink)
Medic09's Avatar
Interesting to see you mention Seafoam. I use it in my carburetted bikes, and quite like it. I was wondering if it is appropriate for an injected motor...
Mordechai Y. Scher
Santa Fe, NM
'76 Trident T160 (rebuilding)
'78 Honda CB750K
'07 aprilia Caponord
Medic09 is offline   Reply With Quote
Old 07-30-2007, 02:47 PM   #10 (permalink)
GJJ
Favourite Bike: 2001 BRG Sprint ST 955i
GJJ's Avatar
Other Motorcycle: 65 Austin Cooper "S"
I personally have been using Seafoam, however there are some who warn about using anything for fear of incompatibility with rubber/plastics etc.
When I use a product I try to put it in correct dosage to a couple of gallons of gas and then use immediately just before totally refilling the tank and diluting whatever cleaner is left.
In the U.S. gas that is rated "Top Tier" has all the additives reccommended. In Wisconsin I get that at Quik Trip.
Gary
Outside of a dog, man's best friend is a book. Inside of a dog it is to dark to read.
GJJ is offline   Reply With Quote
Need help retrofitting to earlier air cleaners Evans Twins Technical Talk 0 12-27-2006 10:55 PM
wheel and spoke cleaners Bigman Twins Technical Talk 10 12-04-2006 03:08 PM
pipe cleaners? SamboGARN Twins Technical Talk 6 09-03-2006 11:54 PM
air cleaners: zooplancton Speed Triple Forum 1 12-01-2005 09:26 AM
K&N air cleaners Maintenance & Workshop Talk 11 02-21-2004 09:10 PM
