You might want to use something stronger and more heat resistant than a plastic bag. The bag will soften at temperature and burst at some point.
SAI exists for the sole purpose of providing oxygen to the headpipe precat and muffler cat catalytic surface.
What you have done will disable SAI. Anything more will require a tune. Triumph (nor anyone else) do not offer a tune for precat (headpipe), cat, but no SAI.
The SAI solenoid valve is normally open. Electrical power is required to close the valve. The non SAI tunes do not tell the ECU to continuously drive the solenoid valve, so the only way to disable SAI is mechanical blockage of flow.
What the non-SAI tunes do is disable the ECU check for SAI solenoid coil resistance. You will have to load a non SAI tune in order to remove the SAI valve and avoid a check engine light.
'06/'07 tunes
20104 cat + precat
20105 NZ/Aus/SA bikes stock without precat/cat
20106 Precat but no cat, no SAI but TOR (US with TOR)
20107 NZ/Aus/SA no cat, no precat, TOR (NZ, Aus, SA with TOR)
Note from the above that the stock NZ, AUS, SA can without catalyst is different and flows differently than the TOR.
