BikeBandit
Old 07-26-2007   #11 (permalink)
speede's Avatar
Our paint jobs are a urethane enamel base coat/clear coat finish, not lacquer. You should be able to tell if the scratch is through the clearcoat by the color of the scratch if it is a white scratch without any color in it you probably aren't through the clearcoat. Take a 3M sponge rubber sanding block wrapped with a sheet of 2000 grit wet automotive sandpaper. Soak the sandpaper for a few hours before using it. DON'T sand without a sanding block and just use your fingers or you'll burn right through the clearcoat. Slowly sand the scratch down keeping your sandpaper clean and the surface wet (patience is the key!!!). The sanding slurry will be a milky white...stop if you see any color at all. Sand until the scratch disappears. Then use some rubbing compound that says "clearcoat safe" on it to bring it back to a high-gloss shine.
speede is offline   Reply With Quote
Old 07-26-2007   #12 (permalink)
Favorite Bike: 2001 Sprint St
MVP44's Avatar
Other Motorcycle: 2003 GSXR 1000
Glare makes a swirl/spider removal polish that may help if the scratch is superficial enough - I have used for a long time and it works very well.
MVP44 is offline   Reply With Quote
Old 07-26-2007   #13 (permalink)
bakwheeltango's Avatar
woowee! I was right!!.... didnt have the details that are so well explained
by speede...
but I was right!! wait until I tell the wife!!!
she'll never believe it. lol
all this talk of wet sandin... takes me back to my airbrushin gas tank days.
I would wet sand the clear coat then paint the art... then my painter would clear over top of the art and wet sand then buff .
here's a tiger I did on a harley... never got pictures of it on the bike. itwas sold and put in a show... apparently I won 2nd place for the art.
X.S Trident V1.0, CF skidmarx huggar, pazzos , smoke lenses, 18th front, K&N, Axle caps, Triumph Tank & Tail bags, Hard Side bags /int panniers
bakwheeltango is offline   Reply With Quote
Old 07-26-2007   #14 (permalink)
omaz's Avatar
Very nice work BWT. Are you a professional artist or is it merely a sideline?
omaz is offline   Reply With Quote
Old 07-26-2007   #15 (permalink)
yes I am and thank you.
I would be interested in muralling a tiger on a new tiger!
maybe start with the black bike and then do something perhaps such as a tiger stalking at night. only lit by the moon... lots of blues.
Old 07-26-2007   #16 (permalink)
Vox
Favorite Bike: 2006 Blue Sprint
Other Motorcycle: Suzuki SV650s Blue
Extra Motorcycle: Wife would kill me.
Duly schooled
What great info! Thanks guys!
Bakwheeltango,
Great work. Made me pine for my '73 CB750 with a Viking dwarf brandishing a battle axe airbrushed on the tank (stolen in '92...bummer). Your work is far superior though.
Vox is offline   Reply With Quote
Plastic Polish Recommendatios meinschaft Modifications & Workshop Talk 14 02-06-2008 08:14 PM
Plastic Polish dkurtz Triumph SuperSports 12 12-24-2006 12:50 AM
Novus Plastic Polish TattooedRedHead Modifications & Workshop Talk 0 03-31-2006 08:53 PM
ABS plastic polish Scottius Sprint Forum 3 03-24-2006 08:43 PM
first scratch... Whisperinsmith Sprint Forum 12 10-05-2005 07:41 AM
