Motorcycle.comBikeBandit
Old 07-25-2007   #1 (permalink)
Favorite Bike: 00Sprint RS - Neon Yellow
RJScotti's Avatar
Other Motorcycle: 02 Daytona 955 CE
Extra Motorcycle: 02 Daytona 1050 (WIP)
Power Commander III
I've got a power commander III installed on one of my Sprint RS. Not sure of how the thing is setup up but it seems off power compared to the non Power commander RS. Anyone on this list with Power Commander experience either way? I'm tempted to pull it out and return to stock (which pulls like a frieght train). Any advice is appreciated.
RJScotti
00 Sprint RS - Neon Yellow
02 Daytona 955i CE - Aston Green
04 Daytona 955i - Black Union Jack Track bike
02 Daytona 1050 Street fighter (WIP)
RJScotti is offline   Reply With Quote
Old 07-25-2007   #2 (permalink)
DaveM's Avatar
Other Motorcycle: I wish
PC
From my limited understanding the PC forces the ECU to do certain things where as the Tuneboy software actually changes the mapping from the ECU.
Dolson or Stlakid can help with this, as well as many others here, I am not a tech whiz
DaveM
Old 07-25-2007   #3 (permalink)
PC doesn't do anything directly to the ECU. PC takes the signal coming from the ECU to the injectors, intercepts it and modifies it to be either richer or leaner.
The fuel map you have installed on the PC might not be right. Instead of pulling it out, I would just load a null (no change) map and see what that does. That would be like running it with the PC removed. You can find the null map at the power commander web site. Another thing could be that you have the right PC map installed, but the three manual adjustment buttons on the PC unit map be messing things up. Return them to neutral and see if that helps.
A power commander map is usually made specifically for a bike from a dyno run. If you don't do that or can't afford it, then you need to use a downloaded map from the internet and tweak it with the power commander software. I found a map on the internet for my daytona and pipe, but did significant modification to it in order to get things to run smooth.
It is worth spending some time to figure it out. Makes a world of difference in power delivery and smoothness, especially if you have an aftermarket pipe and air filter.
ROWYKO!
xactoman is offline   Reply With Quote
Opinions on the Power Commander III RJScotti Sprint Forum 5 09-05-2007 10:29 PM
Power Commander III Brilliant Trotts Tiger Mods & Bolt-Ons 6 03-14-2007 04:22 AM
Power Commander III 955iLimited Daytona Deliberations 2 08-10-2006 07:18 PM
power commander ? JohnXJnj Speed Triple Forum 1 04-07-2006 06:17 PM
Power Commander III for 1999 S3 IIMikeForce Speed Triple Forum 3 12-30-2004 12:49 PM
