Motorcycle.com
Old 08-02-2007   #21 (permalink)
Favorite Bike: Sprint ST 06 Blue
It has been said before, I'll repeat it here. For all those who have problems working the seat screws: Use a ball headed allen tool. Makes your life much easier. And don't overtighten.
Nikos
Do you want to participate in an off-the-beaten-track tour of mainland Greece?
Check below for the big Sprint ST Greek Tour being organised for Spring '08
http://www.triumphrat.net/rides-events/68872-greek-bike-tour-next-spring-anybody.html
NikosR is offline   Reply With Quote
Old 08-02-2007   #22 (permalink)
Favorite Bike: 06 Sprint-Argentum Celer
oldndumb's Avatar
The ball head allen certainly helps with the alignment, but don't forget to ensure that the clips are snug and centered.
Oldndumb
Caveat lector
oldndumb is online now   Reply With Quote
Old 08-02-2007   #23 (permalink)
Sorthum's Avatar
The royal pain in the arse of removing the seat was a contributing factor to my getting a gas-ring tankbag from SW-Motech...
Sorthum is offline   Reply With Quote
Old 08-03-2007   #24 (permalink)
Chillerguy's Avatar
Originally Posted by ricster View Post
I just never bother anchoring my seat down...there really is no need to. I keep the set screws screws in place but never secure the rear of the seat
Um, you might want to not do that. I did the same thing and the fairing around the seat is cracking. It looks like there are a couple of points that the seat rests on that is kind of surrounded on the outside by the fairing. Since my seat wasn't really secured down it would slide forward slightly and put pressure on the fairing. I now have a crack about 1.5" long. I'm tempted to try and claim it under warranty but somehow I doubt they'd go for it.
"I ride fast, therefore I always follow slow people"...sigh...
Chillerguy is offline   Reply With Quote
Old 08-11-2007   #25 (permalink)
rongway's Avatar
I know this may be beating a dead horse, but I have a question and suggestion.
#1 - Suggestion - When removing or replacing the rear bolts for the seat, cut the tube of a Bic pen (the kind where if you remove the top and bottom you have a hollow tube) and slide that over the shaft of the allen wrench. This way, you don't pinch the seat covering and possibly tear it. I got this from a mechanic who works on these quite a bit.
#2 - Question - I have heard that the side bolts on the seats of a 2006-2007 Sprint were for a rear cowling. Does anybody know where I can get one since Triumph decided (apparently) not to produce them? I never use the rear seat and never plan to.
Thanks!
Andrew
rongway is offline   Reply With Quote
Old 08-15-2007   #26 (permalink)
Favorite Bike: Sprint ST!
deetyork's Avatar
Hint when removing seat
I've just removed & replaced my seat fitting a tail-pack, its certainly patience trying -getting the two screws to re-start in the captive nuts is fun! (not!)
If you've got the Triumph/Datatool alarm system fitted remember there's a micro-switch under the seat so have your keys handy or the neighbours won't be too pleased!
deetyork is offline   Reply With Quote
Old 08-15-2007   #27 (permalink)
Favorite Bike: My beautiful black 07 Spr
denman13's Avatar
Other Motorcycle: 84 Kawasaki Spectre (red
Extra Motorcycle: KTM Penton 125 (dirt) now
Thanks!
Andrew
Andrew, try this link. Cowl, hugger, fender eliminator, etc.
http://www.superbikestore.com/sprintst05.htm
Your enemy is never a villain in his own eyes.
Never miss a good opportunity to shut up. - Will Rogers
denman13 is offline   Reply With Quote
Old 09-15-2007   #28 (permalink)
Favorite Bike: 2007 Sprint St
BigFrank's Avatar
Today was my first time fiddling with the rear seat.........I noticed after a hundred or so miles of riding that one of the bolts was not secured.....coming from an aviation back round....it bothered the heck out of me......I finally got both secured after some trying......One of the clips needed an "adjustment"......my question is this......has anyone tried tapping these two rear holes?? Every other screw hole seems to be tapped. Why not these????
If you're not having fun, you're not doing it right.
BigFrank is offline   Reply With Quote
2006 Sprint battery removal jbirdfl Sprint Forum 7 12-12-2007 08:00 PM
2006 Sprint Seat Grommet! airrider03 Sprint Forum 0 02-28-2007 10:10 AM
2005 or 2006 sprint st? ricster Sprint Forum 16 05-03-2006 07:27 PM
GENMAR Riser Installation 2006 Sprint ST lloydo123 Sprint Forum 4 05-02-2006 04:28 PM
Right front fairing removal on 2005 Sprint St GeorgeT Sprint Forum 4 09-20-2005 03:50 PM
