Battery Mystery - Triumph Forum: Triumph Rat Motorcycle Forums
New Bonneville
Old 07-05-2007, 08:27 PM   #1 (permalink)
Favourite Bike: '06 Sprint ST Red One
Other Motorcycle: '07 Honda 600RR
I did about 25 miles into San Francisco today on '06 Sprint, and stopped briefly at curbside. Shut the bike off for about 2 minutes. When I went to restart it, the battery would not turn the starter over, though everything seemed fine on the dash. It tried to start, just not enough oomph from the battery. Turned it off, waited about 60 seconds, and it fired right up. There is no indication of low power while riding. Blinkers, brights, horn etc. all work fine.
Battery is new. Replaced orig with high end battery a month or so ago. Made several more stops and bike started fine each time.
I checked the charging system when I replaced the battery, and it was putting out about 14ish Volts, even at idle.
Any ideas?
Don't confuse me with facts.........my mind is made up.
Yimm is offline   Reply With Quote
Old 07-05-2007, 08:57 PM   #2 (permalink)
Favourite Bike: '01 Sprint RS
norcaltriumph's Avatar
Other Motorcycle: '95 Ducati 900SS/CR
My Sprint RS only starts when the bars are pointed straight or to the right. Go figure...
So was it turning, but just not starting? Or not turning at all?
norcaltriumph is offline   Reply With Quote
Old 07-05-2007, 09:06 PM   #3 (permalink)
Medic09's Avatar
I'm new to Sprints; but on any other bike I'd say that's not right. Sounds like a loose connection.
Mordechai Y. Scher
Santa Fe, NM
'76 Trident T160 (rebuilding)
'78 Honda CB750K
'07 aprilia Caponord
Medic09 is offline   Reply With Quote
Old 07-05-2007, 09:15 PM   #4 (permalink)
Favourite Bike: 2006 Triumph Sprint ST
ricster's Avatar
Definety a loose connection. I had a loose battery connection on my bike and it did the same thing.
Save an animal....adopt and give someone less fortunate a home
ricster is offline   Reply With Quote
Old 07-05-2007, 09:27 PM   #5 (permalink)
Favourite Bike: Sunset Red 06 Sprint ST ABS & Silver 05 Tiger
airrider03's Avatar
Yup, I had a loose connection too and it went as far as blowing a fuse when I pushed the starter button.
I was going to ask if there had been some activity with your battery recently, but you answered that already.
Don't tighten the connection with just a phillips screwdriver...use a socket wrench to get them on tight.
Stay Still, and roll the Earth beneath your wheels...
airrider03 is offline   Reply With Quote
Old 07-05-2007, 09:40 PM   #6 (permalink)
oldndumb's Avatar
Lotsa loose connections out there. :-D
Oldndumb
Caveat lector
Old 07-05-2007, 10:42 PM   #7 (permalink)
Medic09's Avatar
Conspiracy? The evil Dr. Moriarty returned?
Mordechai Y. Scher
Santa Fe, NM
'78 Honda CB750K
Old 07-05-2007, 10:48 PM   #8 (permalink)
Favourite Bike: '02 Sprint
Yimm,
The pre-05 bikes are susceptible to the negative battery terminal loosening up - don't know why. I'm curious why you put a new battery in. Mine have typically lasted about four years in our wonderful California weather. If your previous battery cashed it in prematurely, there may be something else going on.
Bern
PaloAlto is offline   Reply With Quote
Old 07-05-2007, 11:11 PM   #9 (permalink)
Thanks for all the input, guys. I always tighten the connections with a wrench, but I will check tonight and report back. It's too bloody hot in the garage to do it yet. It was 105 F. here today.
I hate the heat. That's why I'm moving to Seattle.
My thinking is I check the battery posts, the solenoid connections, and the starter connections. Did I miss anything?
Old 07-05-2007, 11:40 PM   #10 (permalink)
OK. I braved the sweaty garage. It's still 95 here at 7:30 PM.
Anyway, battery connections tight as a drum, solenoid connections tight as a drum. I can't get to the posts on the starter right now, but I will in the next few days.
Battery voltage was at 12.8, so it is charging fine, reg/rec output 13.4 at idle, with a slight decrease, down to 13.1 at 5000 RPM.
Hmmmmm......................... :???:
Need Help with Mystery Noise Green01SprintST Sprint Forum 30 02-20-2008 11:35 PM
Mystery rubber stu Sprint Forum 4 11-15-2007 05:18 AM
its a mystery to me! doodledog Biker Hang-Out 5 07-10-2007 06:03 PM
Mystery Hose spinner81 Twins Talk 7 05-31-2006 08:05 AM
Mystery Battery Charger Pigtail idaho_thrux Club Cafe' 4 12-13-2005 11:33 PM
