Check Engine Light On - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-05-2007, 11:17 AM   #1 (permalink)
Favourite Bike: 2012 Tiger 800
Other Motorcycle: 99 Legend
Extra Motorcycle: 2002 Speed Triple
Will any OBDII engine code reader not brand specific (sold at many auto part stores) read my 2004 RS's set codes? I have a Triumph shop manual to decipher the codes. I do not want to purchase a Tuneboy or reprogram the ECU. Thanks.
geebee is offline   Reply With Quote
Old 07-05-2007, 01:09 PM   #2 (permalink)
Favourite Bike: '06 Tiger
JasonS's Avatar
Other Motorcycle: '03 Sprint ST
if you unhook the battery you will get the light for three cycles of start/complete-warm-up/shutdown.
JasonS is offline   Reply With Quote
Old 07-05-2007, 02:05 PM   #3 (permalink)
The light has been on for more than 3 heat/cool cycles. I was wondering if I could check it myself.
Old 07-05-2007, 02:26 PM   #4 (permalink)
Favourite Bike: 2002 RS
Stlakid's Avatar
Other Motorcycle: 1981 Honda CB-900F/w full Greer Fairing (#0001!)
It's been a while ago, but I do remember someone on this forum stating in fact that an automotive reader will list the fault codes. I don't remember which brand he used but I do know it wasn't real expensive, maybe in the range of $39.00. It was after all a standard automotive FI system prior to Triumph's use in it's bikes.
My Photo Album
Stlakid is offline   Reply With Quote
Old 07-05-2007, 03:16 PM   #5 (permalink)
Stlakid that's what I was thinking, I think I will give it a try.
Thanks.
Old 12-14-2007, 06:07 AM   #6 (permalink)
Favourite Bike: 1996 Thunderbird "Nessie"
cafetbird's Avatar
Other Motorcycle: 1973 Trump TR7RV "Loosie"
Extra Motorcycle: 1968 BS 350 GTR "Smokie"
So, Geebee, did it work?
Scot Dail, IBA #31553; 59 Club #29906
"Thunderbirds are GOOOOOOOO!"
Old 12-14-2007, 06:23 AM   #7 (permalink)
oldndumb's Avatar
The answer to your question is, yes. OBDII is an international protocol that was legislated so that any shop can have the ability to troubleshoot all EMS's.
There is a generic set of codes that all manufacturers are required to use. There is also a set of unique proprietary codes that each one uses.
So, any OBDII reader will display any stored codes. The generic codes can be googled for translation. The proprietary codes require access to a factory manual for each model and year range.
Oldndumb
Caveat lector
Old 12-14-2007, 10:41 AM   #8 (permalink)
Thanks for all the reponses. I did not try a generic code reader but from the responses I'm sure it would have worked. I had the bike in the T-shop in August and they read the code for me. Turns out, I had a bad Temperature Coolant Sensor it was replaced for about $100 (parts and labor) and I have not had the engine light come on sense.
Check engine light...on again off again monroe731 Sprint Forum 23 03-20-2010 11:14 AM
Check Engine Light HTH13 Tiger Workshop (archive) 5 03-08-2008 02:01 PM
check engine light on? speedytriple Speed Triple Forum 1 06-25-2007 07:35 AM
check engine light robbo1847 Maintenance & Workshop Talk 4 07-17-2006 04:35 PM
