Seat Help - Triumph Forum: Triumph Rat Motorcycle Forums
Ontario TourismMotorcycle.com Classifieds!SportbikeTrackGear
Old 07-04-2007, 01:01 PM   #1 (permalink)
Favourite Bike: Anything Triumph
RickyT's Avatar
I need to replace the transciever that came with my scorpio alarm. In order to set it to my alarm I need to remove the seat. (Dealer put the alarm in). I hear this is a nightmare process so any advice on seat removal would be appreciated.
While I am at it, I might just replace the seat. Which seat works well with the 06 sprint. I have the two pannier system and want to continue its use.
As a child I would never look before I would leap. Things are different now, but I still leap.
RickyT is offline   Reply With Quote
Old 07-04-2007, 03:24 PM   #2 (permalink)
Ricky, the best advice I can give you regarding the removal of the seat is to forget all what you have read about it being a nightmare. It's a two minute job best tackled with a ball end type allen key.
Charlie
Charlie2 is offline   Reply With Quote
Old 07-04-2007, 03:30 PM   #3 (permalink)
Favourite Bike: Sunset Red 06 Sprint ST ABS & Silver 05 Tiger
airrider03's Avatar
Removing the seat is a walk in the park. Putting it back is like getting stuck in gridlock traffic. Replacement is best done with non-ball enders and by not pushing the screw down into the threads, otherwise you may bend the clipnut.
I've opted for the Triumph gel seat from 06, but the 07 options may be better.
Stay Still, and roll the Earth beneath your wheels...
airrider03 is offline   Reply With Quote
Old 07-04-2007, 03:40 PM   #4 (permalink)
Favourite Bike: 2009 Speed Triple
spiki-spikester's Avatar
Other Motorcycle: 2003 Bonnie T100 (cafe'd)
I'm happy with the 06 Gel seat.
Getting the seat back on isn't so bad, as long as you angle the screws at 20 or 30 degrees towards the front of the bike.
Spike's Motorbike Site
Current Bonnie Mods
Now also proud to own
Matt Black '09 S3 w/Arrow Dual Cans
spiki-spikester is offline   Reply With Quote
Old 07-04-2007, 04:15 PM   #5 (permalink)
Favourite Bike: My beautiful black 07 Spr
denman13's Avatar
Other Motorcycle: 84 Kawasaki Spectre (red
Extra Motorcycle: KTM Penton 125 (dirt) now
I found that if you take the retaining clips off and compress them a little then slide them back into position, they tend to stay in place better and line up with less difficulty. And the advice to use minimal pressure while re-bolting will help a lot too. It sucked the first time I did it but once I figured out its little idiosyncrasies it wasn't quite as bad.
As for the seat, I've been eye-balling the Corbin gunfighter. Most people have said it's a fine seat but the customer service is awful. Waiting to see if Sargent will make a seat for the newer models. They will also do custom but very $$$! Great customer service though; I've heard.
Your enemy is never a villain in his own eyes.
Never miss a good opportunity to shut up. - Will Rogers
denman13 is offline   Reply With Quote
Old 07-04-2007, 08:19 PM   #6 (permalink)
oldndumb's Avatar
Are you absolutely sure that is where he put the scorpio? I'm not familiar with alarms because nobody steals Triumphs, but I have to wonder where he found the room under the seat. Maybe it is such a compact unit that there is room under there. But I would check with them before removing the seat.
If you do have to remove it, everything everybody said is correct. :-D
Oldndumb
Caveat lector
Old 07-04-2007, 11:35 PM   #7 (permalink)
Favourite Bike: All of them
NinjaRAT's Avatar
Other Motorcycle: '06 Black Speed Triple
Extra Motorcycle: '06 Sunset Red Sprint ST
removing the seat is easy:
1. use proper allen wrench to remove bolts holding seat down.
2. Remove said seat.
3. Replace said bolts where you originally found them....preferably with the same allen wrench used in the first place.
4. Replace seat.
Done! Next time, skip steps, 1 &3. :wink:
As long as your speed limit is greater than your age, you're good to go!
My Gallery Old Gallery
http://www.danasoft.com/sig/BikeforLife.jpg
NinjaRAT is offline   Reply With Quote
Old 07-05-2007, 05:18 AM   #8 (permalink)
Favourite Bike: Blue 06 st sprint ABS
monkinwitz's Avatar
What i found to be helpfull was to get a screwdriver and lift the edge of the seat vynil forwards this gives you more room to insert the Allen bolt :-D
TAKE NO PRISONERS
monkinwitz is offline   Reply With Quote
Sixty8 Contemporary Seat and Cowl VS Triumph Solo Seat? Lespaul Twins Technical Talk 19 07-18-2008 07:20 PM
Converting king/queen seat to single seat gsx1100s Twins Technical Talk 2 03-27-2007 03:48 AM
will triumph seat cowl fit on corbin seat?? 24gt Speed Triple Forum 9 03-13-2007 03:26 PM
Thruxton Gel Seat vs. Sixty8 contemporary Seat LIJ Twins Talk 6 02-27-2007 01:07 PM
Anyone want to trade their Corbin seat for Triumph gel seat? Sprint Forum 1 08-31-2004 11:52 PM
